Got a Kenwood DDX372BT from Santa today. Install was simple but this damn camera location is whooping me!!! I need to see some pics of where you mounted yours and how you got the wiring there. I think the perfect place is in the center, mounted between the 2 license plate lights but can't figure out how the hell I'd get the wiring to it.
Hey, I installed an Android head unit and reverse camera a little while ago. I drilled a small hole into the tailgate when I mounted my camera to the upper license plate bolts. I ran the camera wires through this hole. If you remove the two plates covering the inside of the tailgate, it is easy to connect to the camera wires. I ran the wires from the headunit into the tailgate taped onto the stock harness for the rear lock.
I tapped power off of the reverse light to turn the camera on. I still have to connect the reverse light to the head unit to auto-switch to the reverse screen. Will probably find some wire at the transmission or shifter for this. I plan to eventually wire a switch in that turns on the camera and switches screen without putting in reverse.
I have the wiring to the tailgate. BUT where do I enter the tailgate and where do I mount the cam? In the location I mentioned earlier, it ain't happening without it looking like ass.
One small hole in the plastic? I understand that. So you're saying run it thru the wiring loom at the bottom of the tailgate, route it up thru the inside of the tailgate, route it with the wiring going back out of the tailgate then pop it out on the bottom side of the plastic 'shroud'? The hole will have to be big enough to push an RCA cable thru because that's what's attach to the cam.
I ran mine inside down to the rear quarter panel and got it through the small grommet down there and then ran it up into the tailgate. Then I mounted it on the black license plate light. If I remember correctly, I notched the back of the black plastic for the table for the RCA after I bolting it from the truck. Then it is screwed in.
Ran coax down drivers side wire channel into rear quarter panel out sunroof drain hole through existing rubber boot into tailgate. Out through license plate light area and mount camera above license plate.
I have it mounted in the light housing of my Slee swing out. Had to replace the light with an led strip to save space. It's off center but still gets the hitch in view which was important to me, I chose a camera with adjustable angles, kinda like an eyeball. Sorry, I don't have any good pics handy but here's a couple bad ones.
subd, been trying to find a good location for awhile, my 4x4 labs bumper with ladder stick out so far it has been difficult. I may try a lower position.....
Ran coax down drivers side wire channel into rear quarter panel out sunroof drain hole through existing rubber boot into tailgate. Out through license plate light area and mount camera above license plate. View attachment 1181140View attachment 1181141
Nope. I managed to push the plug through the boot. You might want to apply some sort of lube - I used some PB blaster dry lube after a while and it helped.
We have them on all the apparatus' @ work & I almost never look @ them. I want it to hook up my trailer (why I REALLY need it to be centered) & when in a jamb rock-crawling w/out assistance/spotter in the rear.
