Aussie "Arctic Truck" on 35's
I have purchased a specific 12V microwave, and yes it will be linked to the ArkPack (New Black Smart Charge Version) directly to run the Mic.
The ArkPack will be able to be charged via 12V charge port linked to car battries. I did it this way so that nothing can fry the sensetive electrics on the 200, will only stuff the ArkPack at worst case senario.
If i had a normal 240 Microwave I would have Connected a 2000Watt inverter directly to my ArkPack to do the same job.
Again to protect the 200's electrics
Hope that helps matey
hey sahara please post how you are going to do the microwave set up; I was planning on just getting the arc pak battery box and hooking up the microwave that way due to the power usage. Are you going to hardwire the microwave???
a 12v micorwave?? never seen one is it any good send a pic if you have time. I thought it would be a regular microwave because you have the ark pak??? I thought the ark pak can handle a regular microwave??? I do not know to much with those pak's but from the videos they have you can charge from the rear 12v plug yes?? I will try to read up on them
look up 12v australian microwave
site Called australian direct
QUOTE=r3run33;8533986]a 12v micorwave?? never seen one is it any good send a pic if you have time. I thought it would be a regular microwave because you have the ark pak??? I thought the ark pak can handle a regular microwave??? I do not know to much with those pak's but from the videos they have you can charge from the rear 12v plug yes?? I will try to read up on them[/QUOTE]
Here is a quick look at latest work done
New intercooler scoop
It's a need to do at some point?
Can't be bothered just yet
