what is the gear ration in the toybox?
what series cruiser is the toybox in, poser, rusty_tlc ?
This one:
That looks like a lot of material removed compared to the amount removed for a stock t-case. Are the Orions a lot thicker in that area?
Nice setup.
Phil
My dream 80 set-up would be stock engine and transmission, ToyBox, Split-case w/ case saver and 4:1 low range...
Change the split case to a Lefty...add a HP 60 and 9" and we're in business. So basically we just need a A44X to ToyBox adapter....someone get crackin on that.
you'll have to translate that for me. I don't know cases and setups all that well (not yet). Research will being soon I hope. Pluse if I can't ask you all to explain that who can I ask.![]()
Working on it...
Oh, and the split case does not need a t-case saver. They are bomb proof I believe, short of over greasing your drive shaft(hydrolocking) and blowing out the output.
And that's good to know about the split case...Question, is the toybox a little light duty for the weight of a 80 series?
Rob
I don't think so... I know guys running them behind V8's and 42's. I highly doubt if that will be the weak link in the chain.
Behind that I would like to use a Toyota "Split-Case" transfer case. In that transfer case, I would replace the low range gear with a 4:1 gearset.
