I have seen plenty of mini truck reduction boxes with broken outputs in the front case.
I still don't think it would be an issue. The 80 is heavy, but I think there is bigger factors as to why a t/c will let go...
Who do you have making your 4:1 gear set that will not fit in the split case?
The Marks 3:1 is VERY TIGHT, to the point that you need to remove A LOT of case material to make them fit.
Yes, I have installed them.
I thought this was a dream setup?!?
Then I will run 3:1 gears in there... I will work out the details when someone makes me a damn adapter!
It would still be the same hardware in my case... I want dual cases, part time, with a lower gearset in the rear case. I want it to mate up to my stock transmission and I would like it to be offset to the passenger side so I can keep my axles.
I would only bitch about that scenario for a second because then I would have to have custom spider 9s front and rear with bobby long joints and mega9s front and rear.![]()
what is the t-case saver & who sells it?
bring this back from the dead
My dream setup factory I6 wit factory auto trani,
Atlas 4 speed
Front Dana 60 outers true hi9 center if it can handle the weight
Rear 14 bolt
now that school loans are close to being paid off time for research on who im gona contract to make this happen
its only sheet metal it can be redone...and you wouldn't have to play butcher with your floor and gastank!
So what engine, trani, xfer/crawl box, and axles would you swap in?With each passing day and having talked to the Aussie's at MARKS and Steven at advanced adaptors
anything short of a Mark's CRawl box is a no go unless ur talking axle/engine swap. It is only sheet metal and I don't care about that, BUT it's $3200 just to get the crawlbox to my door.
hmm, dead threadwhy nobody makes better gearing for FJ 80?
No market and very expensive. Marks 4wd is the only one doing it but very few bite the bullet and do it. And with the economy in the crapper...you get the idea.
If they can make a 3:1 why cant they make a 4:1.
You clearly have not ever seen the insides of a stock USA 80 series transfer case....
The 3:1 gear sets BARELY FIT!
