For Sale Atlanta, GA: 1999 Toyota Land Cruiser
Atlanta, GA
Year
1999
  1. 100 Series
Atlanta, Georgia 30345 United States
Mileage
364251
Color
Blue
Asking price: $8,000
My 1999 Land Cruiser is for sale. I purchased this truck nearly 2 years ago with ~355k miles and it now has ~364k miles. In my ownership I have used it as a second vehicle and have made an effort to get it up to speed on deferred maintenance items.
Additional Photos:
iCloud Photos - Apple iCloud - https://share.icloud.com/photos/055TbAmcB0IdY0GLYfrXVuc7w
Pros:
- Rust free
- Functioning factory rear differential locker
- Functioning center differential locker
- Functioning transfer case
- No issues with transmission
- Functioning 3rd-row windows
- Functioning heated seats
- All speakers functioning
- JVC KW-V660BT head unit (CarPlay, Android Auto, CD player) installed
- Front and rear WeatherTech mats installed
- Lloyd Mats trunk mat installed
Service performed under my ownership (with Toyota or OEM parts, except when not possible or infeasible)
- Timing belt, water pump, and fan bracket replaced (@ 362,891 mi. by @cruiserpatch)
- Idler pulley, belt tensioner, tensioner pulley, and serpentine belt replaced
- Heater Ts replaced
- Front rotors, pads, and wheel bearings replaced
- Brake fluid flush/replacement (by Merriam Automotive)
- Air conditioning compressor and condenser replaced
- Rear driveshaft u-joints replaced (by Driveline Service of North Atlanta)
- Engine and transmission mounts replaced
- Power steering control valve and associated vacuum lines replaced
- Front and rear bumpers replaced from newer model Land Cruiser given by local Mud member
- Wiper blades replaced
- Hood and rear hatch struts replaced
- Gear selector and transfer case shifter knob replaced
- Third brake light replaced
- All light bulbs replaced
Cons:
- Paint is faded or missing in some spots
- Multiple dents, including two larger ones on the passenger side
- Front seat leather is completely worn out
- Interior is well worn and the carpet has stains
- Sunroof is semi-permanently closed (I struggled to get it closed the last time I used it and haven't wanted to open a new can of worms if it fails. It worked flawlessly for the first year that I owned the truck)
- Driver's window sometimes struggles to roll up (this may be solved by new window runs)
- "TOYOTA LAND CRUISER" badge has fallen off (I can provide the badges)
- Suspension is a bit tired (old bushings, shocks, etc.)
- Slight vibration in steering wheel at high speeds (70+ mph)
- Front differential bushings need replacement
- Toyo Open Country A/T tires have 2020 date codes
- Spare tire is from 2008 and needs to be replaced
- No remote key (only Toyota spare key and aftermarket key)
I’m about to head to work but I’m in SC and want it! I can come pick it up this weekend. I’ll be able to talk more when I get off work
