Asian hubs vs. Warns
North Augusta, South Carolina
Almost all of the 40's I have run across have warn hubs on them, and not the asians........ From what I have seen on the board asians are sought after part which leads me to wonder why so many have switched away from the asians? Is one noticeably superior to the other? Also I have noticed more 60 series in my experiences still running the asians...............
My 77FJ40 has Warns installed on it and I would like to go back to the stock asians, but wanted to hear back on them before doing so. Also are the any vendors out there that have used asains for sale? Thanks in advance.
JP
I believe FJ40's came stock with drive plates, and the Warn's were swapped on at the dealerships, or at ports....
Aisins didn't become "stock" until the mini's began showing up...
Same thing that I have been told by those far more in the know than I...
By the way, the stock lock-out for a 77 would probably be a pretty rare bird, as the birf is longer...
But hey, it is fun to dream...
Swap in some Longs, and it would be a non-factor, you then could run your stock lock out..
Good luck!
-Steve
I can add a bit. The FJ55s from 76-78 came with a special long bodied Aisin hub to match the longer Birfield. If you can find these, they work great on the FJ40's from the same period. 79 and later Land Cruisers all came with the Minitruck Aisin hubs though the paint scheme was different. I actually have 1.5 of those long bodied Aisin hubs, but I'm missing a top for one of them. It looks like the top from a later hub would work.
In any case, I swapped my FJ40 knuckles/birfs/spindles/brakes for those from an FJ60 so I have the Aisin hubs even on my 76. The Aisin hubs are definitely nicer. They have a full steel body instead of the mystery pot metal of the Warn hubs. I have heard of Warn hubs breaking, but never an Aisin.
i swapped to the shorter birfs and aisin hubs due to the fact that they are always in the junkyard and most common if somthing breaks on the trail.. i am swapping in minitruck knuckles for the same reason.. once i get some cash for another pair of hysteer arms
Here's what can happen...
https://forum.ih8mud.com/showthread.php?t=42015
not quite right. 79-83 fj40's still came with driveplates, Asco(Aisan) hubs were optional. All US fj60/2 came with Aisan/Asco hubs stock. My green 82 still had drive plates on it when I got it 2-3 year ago. My mustard 82 fj40 has dealer installed optional Asco's on it, also included was the Toyota paper work and install instuctions for the Asco's
I suspect that along with the dealer/port installed Warns alot of folks swaped the Aisans for the Warns because they "thought" at the time that the Warns were an upgrade because Warn has a great name and reputation for Winchs, but in truth the Aisan/Asco is a better hub
I'd rather break a warn hub (that has a LIFETIME warranty) than a birfield (with no warranty)...
Where in this does the name "Selecto" fit? I hope that those weren't Aisin because I got them trashed like junk; I've had two FJ40s wearing Selecto (Selectro?) Matic hubs. One of them had lost the internal splines and one of the other set would not lock in or out because the cover/handle was stripped inside.
Also, a friend has an original invoice showing that the dealer installed Warn hubs as an option at the time of purchase. It's a '75 FJ40
My '76 had drive plates, I keep them for emergency spares if/when the Warns explode -
That being said, I have beat the hell out of fullsize Fords with Warn hubs and the driveline u-joints are always the first parts to go, then maybe an outer joint - knock on wood, never busted a Warn myself but it looks pretty gnarly in those pics above.
Honk- I think the Selectro's were the same deal as the warn's, often dealer installed instead of driveplates. My 74 had selectro's until yesterday. :D Mine never broke, but I sure was holding my breath. I do like the selectro dial much better, easier to grab and turn with gloves etc.
