Arizona Classifieds / For Sale / Wanted
Did you find the issue?
Nope. Newer brakes and brake hoses, new master cylinder, newer (tested) booster. All flushed, leak tested and all checks out. I'm pulling my hair out. Read every forum on the subject. Exercised the ABS. It stops on a dime but the pedal is squishy and goes to the floor when running. :bang: ABS module???
Did you replace the check valve on the booster?
Get rid of that ABS and LSPV!!! I will help for a case of beer.
I am in the same boat. I have replaced everything, multiple times and used GALLONS of brake fluid using every brake bleeding method known to man. Removed the LSPV and anti-lock system as well. Latest seiken booster does not apply sufficient pressure. I am going to try to replace one brake hardline that I had a problem with and a new vacuum hose. If that does not work, I will probably go the hydro booster route. As much time and money as I have put into this, I should be able to out brake a Porsche!
I have a low miles ABS module. I will make you a good deal if you are looking for one.
This seems to be a common issue with the LC's and 4Runners. Thanks to all for the comments and @medtro thank you on the module. I'm going to do a few more tests and I'll let you know, thx
Free - Local Pickup
100 series oem UCA's.
Have 270k on them. Could save someone some time to rebuild these and swap them on instead of pulling yours and doing the same. Located off Gilbert Rd and Germann.
Free - Local Pickup
I will take them if they are still available. Thanks!
^^ paging @medtro !
Thanks @blatant
9 inch led lights a pair 45.00 new never used
cruiser garage ash tray kit 45.0 0
101 and baseline
Drawer slides.
36” locking 500lb rating (pair)
30” 250lb rating (pair)
I sunk $220 into these in 2017. I was intent on building a single drawer setup with a slide on top, but I’ve come to appreciate the flexibility of the open space without any drawer. I carry my spare onboard so volume is at a premium.
These are high quality slides with nice bearings. I’d like to sell them as a set for $150. Save yourself the shipping and the full retail price, which has increased a bit.
@Highway Romping
Drawer slides.
Hey @Cactuscrzr are these still available?
I just got myself an 07' GX470. Looks like maintenance was not the previous owners first priority. Looking for trusty land cruiser mechanic out here in the east valley to replace the Timing Belt, Water Pump, and Radiator while it's all apart.
DM, Call or text, or reply here with referrals.
480.685.6993
Thanks!
480.685.6993
Thanks!
Hit up Scott Higgins @Cruiserhiggs at Avid Offroad. He works on my 80
480.685.6993
Thanks!
Do yourself a favor and put an alternator on it at the same time. I have a GX as well, I did mine when I did the timing belt. Makes it much easier. I’m a tech but don’t do side work, 8hrs a day is enough for me.
480.685.6993
Thanks!
Desert Toy Shop is in Mesa and have always done good work the few times I needed help with a fix on my Toyotas.
