If anyone is interested, this is the response I got back from ARB......if their head tech guy is correct, it certainly makes me happy and now its time to check out my breathers. I have long breather extensions, but they could still be plugged up and I'm using the stock breathers just on the end of a long hose, which might be an issue.
Hi Brian,
We have the pressure switches here and I will have one sent to the address you have provided. The additional pressure will not damage anything in the system and is not related to the oil coming from the solenoids. Oil from the solenoids is typically caused by pressurization in the axle housing. With Toyota's this is commonly caused by the 1 way vent valves getting stuck closed resulting in pressure building as the axle warms up. I would suggest cleaning the blue airline and solenoids with brake cleaner (unhook the lines at the axle housings) followed by compressed air. Next, replace the vent valves (assuming you still have them) with a barbed fitting and fuel line to allow the axles to breath properly. More than likely this will resolve the issue, however, if the oil does return please contact us at the number below and we can discuss it in greater detail.
