Hwyyyyy...! Just checked.. Yup! IPF LEDs DO work as DRLs! No flicker either!
Wow, that's amazing. That's literally the first LED replacement bulb I've ever head that can handle voltage drop and not flicker. A testament to IPF's engineering.Hwyyyyy...! Just checked.. Yup! IPF LEDs DO work as DRLs! No flicker either!
I'm gonna give the high beams a go. I run a different name brand low beams and they are great so no need to replace them. I'll just add these as my current high beams are WEAK SAUCE. Good find guys - thanks
That's an interesting point @Markuson I'll try the mix combo first and see if I can't get lucky with what you're describing above.
thanks for the info
Nice @Willy beamin ...
-Just a thought...but one reason you MIGHT still want to consider the lows too...is that for some reason, the switch to the IPFs somehow automatically keeps the lows ON with high beams!! So you not only get stronger highs, but you get four lights instead of 2! I've always been annoyed that we lose lows with highs unless wiring/resistors are tweaked....but IPF lows solved this.
-Now if I could just get my LED fogs to also stay on, I'd have one sweet swath of light!
I believe shutting off the low beams and the fogs when the high beams are on is a DOT requirement. I know it's required with the fogs, but I have also read the low beams need to be turned off too. Or it might be the manufacturers are doing that to protect the alternator/battery from all the draw. Which is a moot point with LED bulbs.
I'm sorry. It's $30 off of $300. I bought hi and low beams for my Tundra and it was enough. I would like to get fog lights too, but the IPF 9145/h10 fog lights are not available stateside.
Did anyone actually get a tracking number from Morris 4x4? I ordered the 301 HLB to use in my fogs. It says in their site my order is "shipped-complete" but they didn't provide tracking info.
It's been a couple of days now. Still no tracking number, and not a single reply to my emails. Should I be worried?
I installed the highs and lows last night. Not bad.
Anything in particular that didn't live up to your expectations?
