Does anyone use there FZJ80 to pull a boat? Wondering about steep ramps and steep grades down to some of the marinas and boat ramps and how a 94 stock FZJ80 would do.
It has the towing package and the 5000 lb tow rating. Not concerned about overall towing but concerned about the steep ramps and sometimes the unseen pavement drops in the water. Some of these boat ramps and marinas have some steep grades to get to and from them. I would think low lock would get me out of the water okay if I needed to pull it up over a drop. I would take it slow up the steep hills (may have no choice
The boat I would be towing is a 1982 Sea Ray 210 Cuddy Cruiser. Not sure exact total weight with trailer but around the 4500 lb range I would guess. Need to look into it more. Tandem axle trailer with surge brakes. 21 ft boat.
I will add I just purchased this 94 FZJ from board member Twiggles. I feel I am already an addict after two days of driving it. 150,000 miles, lockers, white, no roof rack.
This be the boat; These classic Sea Rays are heavy boats.
Thanks.
Thanks.
got tired of my road rage and made me buy a place. Anyway, you don't need the 7 pin fix to take care of you at the ramp. In fact, I'd say the oppoosite. Always use your low range to treat the old gal right. Have your tranny fluid flushed and replaced with synthetic and be easy on the OD and that bus tranny will never die.
I should have thought of this as my Dad's old GMC 2500 had the wriing on the front diff torn off by barbed wire and I was able to do that very thing in low range. Great, great point.
