Anyone recognize these holes?
Connecticut
I have two holes on my passenger side cowl just above the vent. I thought perhaps they were for an antenna but I have not been able to identify what one. It is not for the FJ40 radio antenna I bought. I’ve looked at a lot of CB antennas but have not found one with this hole pattern. You can see the faint outline of whatever was there. Any ideas?
The holes in your sentence? More?
Everyone has holes. Just some are different than others.
Aftermarket radio antenna? Not OEM.
I think that is pretty common for antennas with a single base. One hole to pass the antenna cable through (the big hole) and one to keep it from rotating. Mine had two nuts of the same size for mounting as you can see below. I think on yours it might have been a single sheet metal screw. I welded the holes closed and installed in what appeared to be the more OEM location.
Here is one that looks like your hole pattern just upside down.
RetroSound Volkswagen Antenna
that looks like the Toyota antenna bolt pattern. the small hole is for the retainer clip.
I think... ;)
I purchased that antenna from another vendor, it is not even close. I also dont see any of the usual signs of adding an AM/FM radio. For music I am going to put a single din unit in my tuffy console. My suspicion is the holes are more likely a CB antenna based on the diameter of the larger one. CBs are not an area I have a ton of experience so I hoped someone would recognize it.
These are the two common types of side mounts I have found (excluding 90 degree brackets).
attachment.php
I am sure either can be made to work, just trying to see if replacing what was already there is another option before drilling new holes. :eek:
