Anyone else running just one cat?
Orlando, FL & Southampton, NY
A couple weeks ago, I had a little scare when my rig temporarily lost power and overheated slightly, shutting off my A/C while I was on the highway.
Turned out to be a clogged secondary cat
https://forum.ih8mud.com/threads/ha...-the-drive-home-temporary-overheating.813602/
I gutted it, left the primary cat in place and immediately noticed a boost in power that I haven't felt in long time, so it was probably clogged up for a while :eek:
I've put about 1700 miles on her since then with zero issues and no MIL :cool:
Just curious, but is anyone here running with a gutted Y-Pipe and just a secondary cat without throwing a code?
Reason I ask is because I replaced my leaky y-pipe seals when I gutted the cat and I'm pretty sure the clog was the reason it started leaking in the first place (either that or Bosal's $h!tty mating of the flanges)
Well, a couple nights ago, I noticed one of the Y-Pipe seals started leaking again :redface:
The primary cat was still in tact a couple weeks ago, but a little on the dirty side...
I figure if it's on its way out, I can either gut that one too and bolt on a new secondary cat or just install an O2 sim :meh:
No smog here in FL, so it doesn't matter to me either way, but I'm curious if there's anyone here just running a secondary high flow cat alone without MIL issues :hmm:
I have just one cat. Was that way when I bought it a couple of years ago. Never any problems. Not sure of a brand, i could try to check for markings if you'd like.
I have a 91 with no cats. No CEL issues either. I had them removed when I bought it and had the entire exhaust replaced.
-Derek
Is it the primary or secondary cat?
This is what the Bosal system looks like
I have a single cat. The front O2 is the important O2, it is the closed loop sensor the second O2 is the cat effeciency. You can run 1 cat and space the rear O2 sensor out to not get any codes....
But which cat are you running?
I'm wondering which cat is more efficient than the other :hmm:
With no rear cat, I'm not getting an MIL :smokin:
Would it be the same if I was running a gutted Y-Pipe and a new rear cat?
Would suck if I went through the trouble of gutting the Y-Pipe cat and installing a high flow secondary cat (maybe MagnaFlow?) only to throw a low efficiency code :doh:
I have the EMS y pipe and cats. No codes. Fit was terrible though. Had to have and exhaust shop redo it.
Also, for reference, driving in 90+ with AC on high in stop and go traffic...temps never exceed 190 per Ultragauge.
On my 97 Landcruiser (not my 97LX) I had both cats removed and replaced with one high flow. They cut the first cat off at the Y pipe and and put in an extension tube. Other than the s***ty welds that the shop did, everything works great. Truck seems to run much better.
I had this done to accommodate custom sliders that I purchased from someone who wrecked their rig.
Thinking about redoing my exhaust. Removing the cats and putting another muffler. Do I leave the o2 sensors? Replace them both with new ones? Any idiot lights come on and how to get rid of them if they do? Thanks...
If there's nothing wrong with your O2 sensors right now, the you could just have the shop weld new bungs in and reuse them. No biggie.
This is what I have. I think like @toddsmith1 said his was
What
year is your cruiser? If it is a 93-94 it couldn't be easier.
OK, a little update.
Pulled the Y-Pipe again today to change the seals and found the primary cat was a bit more filthy than the last time it was down:doh:
It was most likely why the seals started leaking again :hmm:
So out came the pry bar and hammer....
Sealed her back up, put 55 miles on her and she has yet to throw an code, but I'm sure that will come within the next 2 drive cycles :meh:
I have a single magnaflow high spun cat. Its tiny! Throws P0420 once and awhile. I just shut it off with the scangauge. On a 96
This might be slightly off topic due to the year of my 80 but has anyone made a y-pipe for the 93-94? My cats are plugged and I want to go single cat like the OP buy have the "long tube" separate headers and cats.
That being said OP I recommend the magna flow. I had one on my jeep previously and it worked flawlessly. I plan on going the same with my cruiser.
I have a single aftermarket bolted in place of the two OEMs (flange welded to the Ypipe to bolt the cat to). No smog check here to worry with. Throws a 0420 once in a great while when I cruise about 30 MPH and let the gas pedal up just a certain time or something...I just reset it and move on. I spaced the rear O2 sensor out by one more gasket, might add another before things get too rusty.
