Any Suggestions?
California, USA
The PO's PO of my cruiser was a volunteer fireman and had these lights installed in the front grill of the cruiser. Currently they're wired in the cab with a three position switch to on/off/flash. The big problem is that since I'm not a "man of the law" it's illegal for me to run blue lights (the gold spray paint is the PO's fix :rolleyes:).
To get to my question....
Does anyone know of any decent offroad lights or housings that would serve as offroad lights that I could swap these with. I've done some poking around but I've mostly just seen the "bolt to your car" style. I've got a 4.5" hole in the grill as is but I'm not against widening it since it's already way past OE. :D Any suggestions/recommendations would be appreciated.
Thanks!
OEM fog lamps
Aren't original Toyota FJ40 Cruiser fog lamps that bolt onto the front bumper and have a dash swith to turn them on available?.
They are here. The dash switch looks just like the headlight switch, but has indication that the beams will point "down".
I'll second Noah. While it certainly is admirable to serve others, the last thing I would want is my Cruiser to look like a cop wannabee. Those things gotta block airflow and they make your Cruiser look like the PO's creation. I'd replace those with unmolested used parts and hang them on the wall of shame. ;)
I second taking them out. However, one alternative would be to find some clear lenses to swap in = mini off road lights. Another option would be to take them out but keep the wiring and hook up some good off road lights on the bumper. You would just have to extend the wiring a bit, but you already have the switch.
Good luck!
One other quick point: try to give your post/question a descriptive message. It will get better attention from knowledgeable mudders etc. It also helps with the future search and archive function. Try to avoid titles like "help needed", "cruiser question", "advice needed", "opinions please", "can someone help me" etc...
Cheers,
Max
I agree that the cruiser would be better off without the lights there, however I'm more interested in a temporary fix until I can get the cash together for a new bib and grill. As long as the lights are there I may as well use them right?
Removed them and I agree it's blocking the airflow to the radiator. That is more important than cosmeticly worrying what to put in it place. My opinion is remove them and put some type of screen over the holes until you find a suitable replacement.
1973Guppie said:
why not just get a used bib and front grill? along with some new turn signal and you are back to a nice stock looking vehicle, if nothing else it would probably up the value of the car quite a bit.
Noah
x2
Pull em and go toward original as long as you've opened up the cap to pour money into!
I'm sure it'll turn out nice.
Good luck
Scott
