I know there is a love/hate relationship with this vendor, but here is the link anyway.
Antenna Mast Repair Kit 91-96 [1991-1996] - $49.99 : CruiserParts.net, Toyota Landcruiser Parts
I own a '96 LC and ordered a mast from Cruiserparts.net and received the wrong part. I ended up having to order one from a Toyota Dealership parts department using my VIN. If all you need is the mast, and not the nylon cable, it's an easy fix. Run the mast all the way up and unscrew the mast from the cable and screw the new mast into the cable and run it back down, done. If the nylon cable is broken inside the mechanism, you'll have to remove the unit and take it apart, clean everything up, re-grease, install the new nylon cable, put it back together and re-install it in the fender. Then install the new mast as mentioned above. Good luck!
I just bought one of these. It works fine with my 1997 LX450.
Amazon.com: AntennaMastsRus A031-60080 Toyota,Lexus Power Antenna Mast: Automotive
The one I linked definitely has teeth and is for the later models.
Most likely the mast will solve the problem.
I have a 97 Anniversary FJZ...... my antenna/mast is out of rig. Notched/geared cable is broken with about 4 inches hanging out if in 95% down position. (Antenna compressed all the way down to only the skinniest tip section extended) I cannot get tip off old antenna otherwise it is not bent. Just the broken cable. Do I just need a new mast and that is it true I can feed the new cable down in there and leave old? Can I call the desk and talk to you and order required part? Thanks Cruiser Dan. DLP
I retired from the dealer parts business earlier this year and I am now the Curator of the Land Cruiser Heritage Museum in Salt Lake City UT.
You can obtain a replacement mast from any Toyota dealer, the part number is 86337-60080. You will need to remove the antenna and disassemble it in order to remove the broken cable. Do be careful however because if you lose or break anything in the process you will need to replace the entire antenna assembly.
hope you are enjoying your retirement Dan,
and can anyone tell me if this p/n Dan mentions is 1997 only or will work for a 96 that does NOT have the auto antenna feature ie only goes up/down with the dash pushbuttons? I have searched but that is the only p/n I ever see mentioned
thanks
doug
86337-60080 applied to 96-97 LX450 and 97 Land Cruiser. 91-96 Land Cruiser uses 86336-60040 which does not include the nylon cable.
