- Thread starter
- #881
The factory fuel supply and return lines ended up too low on the firewall and would have been difficult to hook up to the VW filter housing, so I ended up trimming them back.
@90WT kindly lent me his brake line double flare kit, it worked great for putting a bubble on the ends of the fuel lines. Tested first on one of the offcuts, just needed a bit of a chamfer before using the flare tool.
Space was tight getting the tool in there and working on the hard lines, but it ended up working out well.
Looking at hooking up the high pressure power steering line, I think there is just enough length in the hose I made up for the ALH swap but the banjo fitting points in the wrong direction. The hose ends are -6AN, there aren't a lot of male-female adapters available but a 90º or 135º would be ideal. One of my local auto parts stores carries a pretty big selection of hydraulic fittings that are the same flare and thread as AN fittings, so I'll drop in there and see what they have that might work. I'd rather not have to make up a whole new hose, but it may come to that.
