I found a pretty complete 2F on CL for $350, that was supposedly running that came out of an '75 FJ55. (Block serial number is 2F 026033 and head is a 61030). The PO said when he bought the 55 a couple years ago, the PPO told him the motor was recently rebuilt and that he was having a hard time getting the Aisan carb tuned, so he put on the Weber. He also said he has only driven the 55 around town since he bought it and it ran fine.
My plan was to open it up, survey for any obvious issues, then change out the easy to get to gaskets if all seemed okay. Mind you, my wrenching experience is limited, but this forum has been a BIG help in getting my confidence up to tackle something like this on my own. That being said, I don't have eye yet for what is good, bad, or out of place.
When I pulled off the head, I found what appear to be flat pistons in a domed piston engine, then I thought it might be possible that the PPO milled the head to accommodate the flat pistons, but I don't know the difference. Thoughts?
That I can tell, the cylinders are not grooved, but there is some pitting. I'm guessing the pitting would make it a candidate for boring, which if the head is not correct for the flat pistons, the block becomes a boat anchor, as I've read.
If the block is a loss, what early 2F parts can I salvage to use on a later FJ60 2F? Like I mentioned, the motor is pretty complete with the 4spd bell housing, I have the Weber carb, and a couple of Aisan carbs he through in, the tins, a new alternator, water pump, etc.
Any insight or help would be appreciated.
Dave
Dave
