- Thread starter
- #21
O yea, and if your pinion or axle seals are leaking I'd fix the breather and see how it goes.
No leak from axle or pinion.. Thanks
Did it actually "spray" out or just run out? Good possibility that it was just over filled, especially if pinion and axle seals are not leaking. But, I'd check and test your breather, anyway.Fianlly got to the rear diff today. After a short drive I decided to pull the rear plugs. The upper was rusted pretty bad, so after beating on a Impact socket, I was able to pull it. To my surprise, it was under pressure, sprayed out a little oil
Could this be a sign of a stuck breather valve?
Check the diff breather, the diff shouldn't be pressurized.
80t0ylc, do you have a bypass filter installed? I would like to see some pics
Thanks
stu
On Monday I decided to pull the trigger and go synthetic in the F/R Diffs, TC and Power steering..
Any difference with the Amsoil in the trans? I'm currently running 10/30 signature in my engine and long life 75/90 in the transfer case and will be putting it in the rear diff Thursday or Friday.
so it got put to the bottom of the list.
