Steel said:Does anyone know what factory amp gauge came on an 11/78 FJ40? When I bought my project it didn't have the factory gauge cluster, so I picked one up on ebay that has a -30 to +30 reading. I assume that since the alternator is 45 amp I shouldn't use this gauge????
Thanks
Poser said:F that shunt crap...
Take it out of the system, and install a volt meter, and be done with it.
In the end, no matter if you have a volt meter or ammeter, you will know when your charging system is not working properly, and if you are not paying attention enough to notice, you will be walking when your battery finally dies.
X2 big timePoser said:F that shunt crap...
CruisinGA said:therefore, I am modifying the stock ammeter to use an external shunt, mounted to the alternator or nearby so that the distance current must travel from the alternator to the battery is minimized and kept out of the cab. This also means that any alternator within the amp range of the external shunt used is safe while keeping the factory guage in the cluster. (the range of the guage will be changed to those of the shunt used)
Pin_Head said:
