all windows just quit 89/fj62
Winston Salem, NC
searched but nothing with all them quiting.
So today I ran some errands came home turnd the vehicle off, went back out this evening to put her away and to put the windows up.
the master switch and none of the other switches work, all of the sudden.
I did just put door speakers in yesterday, but they worked sense
i suspect :
It’s a plug thingy connected to the battery + terminal. It has 3 wires in it that are fuses.
Looks something like the picture below
Do you think anything was altered when you put the speakers in, as in pinched a wire or a connector is loose? If not then maybe take the master switch back off and see if you are getting voltage to the switch connector.
View attachment 3006586View attachment 3006585
Oh yes those, well if it were those wouldnt i see other electric issues? or is one specific to window motors?
the door locks are working. i know its a separate circuit
Faulty relay?
@Spook50 any ideas?
Faulty relay?
@Spook50 any ideas?
If it were just the driver's window no longer working I would suspect the relay box, but someone beat me to my first guess, which is what turned out to be the issue: circuit breaker
well i located the issue by finding the breaker and reseting it.. doing that allowed me to find what tripped it, the pass front was now the only one not working. i removed the door panel and located the issue.
a speaker screw grazed the window switch harness and ground out..
a little burnt ozone and patch, good as new.
