Alignment advice please
Orlando, Florida
Can some of you knowledgeable chaps take a quick look at my alignment numbers and let me know if they are all good. My main issue is with where they list "Specifications" not sure if those specs still hold true when you have a 3" lift. Also looking for confirmation on my caster correction before I have the plates welded.
Thanks
j
Call me a liar, but I'm willing to bet that the red are bad and the green are good. Since camber isn't easily adjustable on these trucks, I wouldn't sweat a tenth of a degree. Well, at least not on a low performance SUV...
Wheels on the turd go round and round
How can you have a full degree difference in caster between the left (2.7) and right (1.7) sides on a solid axle vehicle?
Inner knuckles are welded slightly off-axis. Known as cross caster
So are they supposed to be one degree off, then?
I dunno what the ideal is. I thought usually its the other way around but it could be intentional due to awd or something. That or the manufacturing tolerances are just not that tight, though I sort of doubt that.
So how did they coerrect 0.2 degrees on one side and 0.5 degrees caster on the other?
I had similar thoughts. How do you even adjust caster without rotating the axle?
I'd check your wheel bearings for play
Thanks Rick. I checked them in October when I did all my oil changes etc. Will check them again.
You can't. Caster correction essentially rotates the axle, unless you cut, rotate and weeks the knuckles, or install offset trunion bearings.
Factory specification for caster is 2° +/- 1°, left and right, so I guess the factory tolerance could mean up to 2° difference from left to right.
If you are going to a 3" lift, aiming for 4° of caster is a good idea IMHO
Yeah, I'm thinking if caster was changed at all, they'd both change the same amount.
The only thing that is ever going to change during a typical "wheel alignment" on these rigs is toe in/out. Anything else requires installing aftermarket parts.
Bad idea. If you get there you'll likely have bad vibrations that neither a stock drive shaft or DC drive shaft will cure.
maybe. seems to vary from one rig to another.
not my experience. I did a cut and turn on my 80 with 4" lift, set to 4 degrees caster, stock front shaft and tolerable/mild vibration from 50mph up
How does it drive/handle? IMHO, chasing arbitrary numbers is a recipe for fail on a modified rig, especially using stock numbers. That said, don't see anything I would worry about?
Don't know what work they did, but riddle me this: On a straight axle rig, how did they change the caster .2 on the left and .6 on the right, twist the axle? Many see the techie stuff and think precision, in reality, not so much. To me this speaks to sloppy setup and/or intentional manipulation of calibration to make easily explainable numbers, totally common. On straight axle rigs, I prefer to do my own alignments, doesn't take any trick tools.
Right, I was gonna say if they managed to change the camber they either jumped it off a loading dock or their measuring equipment is just not that precise. Numbers look fine to me :meh:
I can see that they manage to move caster that much, did you install anything to adjust caster? Unless you have any steering issues I won't
worry too much about it. The factory specs. is just a reference for the technician it doesn't't mean it's bad when things are in the red unless it's way out of the maximum/minimum specs. I prefer having a lot of caster regardless if IFS or solid axle it keeps the vehicle going straight on the road, camber should be minimal as close to 0* if possible unless it's a race car.
So you set caster at 4* and have drive line vibrations.
