ah crap - seat problems
Sheboygan, WI
So my drivers seat decided to stop moving tonight - can someone confirm that this is where that end cap should be that pops off? Hopefully if i stop at a local stealership I can get one ordered -- or stolen off another toyota? Are all power seats the same? I wonder If I could borrow one from a ran
Thank you!!!! I will get it ordered right now! at least it is on the drivers side so it will be a quick fix!
You will probably need both the endcap and the gear from Gamiviti, if not 2 pair for each side of the seat. He's a great guy with whom to do business, but make sure you are meticulous about following the directions.
Here's the link: http://www.gamiviti.com/html/products_seatparts.html
I recently installed a new cap and gear only to put the seat back in and realize that both gears in the seat were bad. So as Beau stated above you might think about just ordering a cap and 2 gears for the seat, or at least look at the gears first. It would save you some money to order at the same time. Super easy job, but do pay attention while you're doing it.
Yep just did mineas well recently. Just make sure you are careful. It's easy to crack the gear. it helps to put the gear and the shaft in boiling water to soften up the plastic. I've cracked a couple
I'll second Gamiviti being great to deal with and also to follow his instructions VERY carefully. As always, measure twice, and in this case, install once. It's critical you get the two seat rails lined up exactly or it'll be crooked and you'll strip a gear very quickly!
Crap - Just put in my new cap and I have nothing. I guess I will have to order the gears and do the hard way :-(
I try to add this to all of the many seat don't work threads - do yourself and favor and don't try to do the quick fix, unless you want to do it several times.
I fixed my seat with a new oem gear, prior to Gamaviti offering the gears. Then a few years later it went out again, another stripped gear. The gear boxes that the gears go into and that the cap screws into has grease that is now upwards of 20+ years old. In the case of my seats, that "grease" had basically turned to sticky solid varnish, putting stress on the motor, making for tight gears and bad operation.
So I took the seat out and greased the screw drive paths, and actually took the gear boxes out and cleaned out the congealed gunk in them. It took about 2 hours to do so, I'm sorry to report, from removal and disassembly to reassembly. Then repacked with new white lithium grease. The seat now moves quickly and without straining.
We tried telling you to order the gear and meticulously follow the directions. Slapping an endcap on your seat will no longer fix your seats than a wig will cure the cancer of a chemo patient. If you read the directions, you understand than when the endcap falls off, it is no longer aligned and this results in the gear being stripped. You just closed the barn door after the horse left. Put the horse back in the barn (new gear) then lock the barn door (new endcap).
Use the search before you post, this has been addressed nearly ad nauseum. There's a lot of good advice here my friend, but it only works if you follow it. Good luck.
FWIW I used Dow Corning Molykote 33 (Medium) grease for the gear box and jack screws, it's a lithium based silicone grease which is compatible with plastic gears.
Finally got the seat fixed. Someone on craigslist was parting out a '91 LC and had the cloth manual seats. They are not near as comfortable as the old leather seats, but the cloth seats look great and are the right color. When I was taking out the drivers seat it magically starting working again. Now I just won't have to worry about it again, electric plastic caps and gear problems solved forever!
It might be there in the directions, but I missed it, if so - the part about having to raise the front edge of the seat all the way before removing it so you have access to the lower front trim screws.
When I clicked on this thread I was half expecting a picture of brown skid marks on the seat and a sweet picture of the cruiser on an off camber ledge overlooking jagged rocks.
Let's just say I was a little disappointed
