Aftermarket backup camera installs
Thingfisher, it does NOT obscure the license plate at all. In fact the camera is tucked under the cargo door and it is hard to see the camera standing directly behind the vehicle.
Its raining here today, so these pictures are pretty bad.
Here is a picture of the camera and my license plate. I actually had to squat down and slighty point my phone up to actually get the back up camera in the picture.
Here some other pictures with the cargo door raised so that you can see how it installs:
Here is one with the camera module hanging out. You can see the gray thing sticking out of the back is the original license plate light bulb socket that sticks into the camera module (this way the license plate light still does it's job). The whole thing just clips up in the hole.
Lastly, here is an image of the view on my head unit. Sorry there isn't more in the image, but I was at work and just took a quick picture. Also, the image looks a little weird because I took it from the side instead of straight on... If you look at the bottom of the camera image, you can see my bumper (and my hitch receiver just barely sticking out - with a ball installed you see the ball really well), and the truck in the top right of the camera view is about 35 feet away. This field of view will very depending on the camera lens, I just wanted you to see what mine looks like since the camera alignment is fixed.
Again, pulling the wiring is the most difficult job, especially getting it through the cargo door and through the rubber sleeve into the interior of the cargo area. It takes a little planning and I did do some splicing (but this is required for any reverse camera). But I know the wiring is well protected and always there. Sorry I don't have pictures of running the wiring, I did it a couple of years ago. Its not that hard, it just takes some time and you do have to pull some of the cargo door trim, and trim in the cargo area. Once the wiring is in the interior cargo area, its easy to run the wire to the front of the vehicle, just start pushing it between the trim and the carpet, and under the door sills; its a pretty quick path to the front and up to underneath the dash...
If you have more questions or want more pictures, let me know.
Hope this helps.
Lee
2000 LC
2004 LX470
How is that camera powered? I have been thinking of how to add a wireless backup camera that would connect with my ipad that I have mounted on my dash.
Hello....Has anyone had any luck replacing the factory oem camera with an aftermarket camera? In otherwords, i am looking for an aftermarket camera that i can use with my 2006 factory Nav/head unit. Thx!
OK...so you still found have to route the camera wires out of the tailgate window. I was hoping you could wire it from the license plate light
You could, but the camera would only be "on" when your lights are on. You're gonna have to run the video wire anyways out of the tailgate, unless you get a wireless camera.
I am also interested in this. My factory backup camera is nearly impossible to see anything with unless the lighting is perfect. I’d like to use the factory setup but with a better camera.
@Thingfisher I just found another discussion thread with a camera that I like better (posted by @LostAfrican)! Camera looks the same as the one I posted earlier, but it has a gyroscope (I presume) and moves the lines depending on which way you are backing... See this thread:
Back-up camera with intelligent tracks
I've ordered one, I'm assuming it will plug right up to the existing wiring I have already run for the other camera.
upload_2017-8-16_18-21-13-png.1518544
Lee
2000 LC
2004 LX
Thanks @leej . I had the backup camera you used installed a couple of weeks ago, and I've been very happy with the performance and the look. This new one with the gyro adjustment is something to upgrade to at some point. Nice find!
This can be achieved the same as going into reverse, you just power the input so it thinks you're in reverse, the switch can be a change over switch, you either select power to turn it on or in the opposite position, it turns on when reverse is selected.
Would like more info on this, realizing this is an old thread. Trying to do right by researching before creating a new thread - lol. About to install a Jensen head unit so I have apple car play and a backup camera. I like the idea of it automatically switching on in reverse, but would also like the ability to turn it on to see behind me when not in reverse.
Camera came with a license plate mount bracket, but not seeing a good way to get the wire inside without drilling a hole behind the license plate. If I run it through one of the 2 screw holes what holds the plate?
Reverse power can be gained from up front ECU wiring etc and any other ign power source, both into the switch then down to camera etc, but if feeding from reverse lamps for power signal, worth putting a diode in so your reverse lamps aren't powered when you switch the ign feed that you send the camera.
I'm looking for ideas on where to mount my Kenwood CCD-2000 backup camera. Anyone have pics of their install?
Bottom center of my rear BIOR bumper.
