Adding grease?? Checking Fluids??
Milwaukee, WI and Louisville, KY
Is there a way to inject grease into the birfield without taking it apart? My mechanic can't get to replacing it until next week now.
I thought as a precoution I could get some extra grease into the unit. Is this even possible?
Second question. How do I check the fluid level at the axle/tire. I have read comments about checking the levels by taking the cap off and sticking your finger in. Sorry for the very elementary question. The previous owner is sending me the Toyota Service Manual.
JP
On the top front of the Knuckle, there is a square head plugs, 12mm, I think. This can be removed for adding grease to the knuckle. Check the level with a wire or screwdriver first. They should be 1/2 to 2/3 of the way full. If you put in too much grease, it may damage the inner seal. See Post #7 in Romer's frond axle rebuild guide, https://forum.ih8mud.com/showthread.php?t=78276 this plug is just to the right of the ABS sensor which is being removed in the picture. BTW, use Moly Grease.
The diff has a fill plug on it. You can remove it and if you think of the diff as a bowl, the surface of the fluid should be about even with the fill plug hole. You can stick a finger in and feel when you touch fluid.
Instead of simply checking the level, why not flush the fluid and replace with new? It looks like you have not done this baselining yet.
This thread https://forum.ih8mud.com/showthread.php?t=119070, among others discusses how much fluid to put in. FSM says 75W90 gear lube.
x2 but make sure to loosen the fill plug first.(obviously the drain plug is the one on the bottom and the fill is on the face)
Yes there are greaseable birfs
https://forum.ih8mud.com/showthread.php?p=2214285#post2214285
Or as stated earlier, remove the square nut, add grease. If you are using a grease gun and you have not added grease in a long time be prepared to add one to one and a half tubes of moly di.
The level of grease inside your knuckle will correspond to the level line of grease visible from the outside, sort of like the dirty ring around a bath tub.
Pay attention to travel of your grease gun nipple in the knuckle, the filling cavity will try to eject your grease gun nipple giving you a very reasonable estimate of when your knuckle is near full.
PS My DD has one GearingDynamics greaseable birf and one OEM birf, and to my surprise both units took exactly the same amount of grease during their last service thus proving to me that both systems work.
I would wait for the front end rebuild before changing the diff oil provided that it is in the near future. If your inner seals are leaking, your new oil will get contaminated with birf grease.
