Adding 2nd Gear Start Switch to a '93???
Tuolumne/ Rancho Cordova, CA
Is it possible to add a 2nd gear start switch to my '93? I'm guessing I won't be able to since my A442F transmission isn't computer controlled but it would be nice for driving in snow and sand.
Yes, you already have it.
Shift into 2nd gear instead of 'D'.
You can shift up to D after you get going, by simply pushing the shifter up, no stopping required.
Not quite the same thing as I understand it. With the second gear start in the 100, the truck will actually start in second. If you just put the transmission into 2nd, you will still start in first.
If I place my 92 cruiser in 2nd it does not down shift to first. It starts in 2nd stays in 2nd until I shift out.
That is not normal.
Cruising through the desert is a useful place for this as well particularly if the terrain is rough enough that you are in 4L. Last year during CM I was riding with DMC in his 97 and the trail we were on had lots of ledges that needed 4L. But between the obstacles were short stretches of sand that you could get moving quickly on. 4L has quite a lurch when shifting from first to second in that scenario. The 2nd gear start switch made that a much more enjoyable experience.
Since i have a '93 as well I'd be very interested to hear if this mod is possible.
back to your regularly scheduled programming........
It is normal on the 440f tranny of the 91-92 80's. I believe it is also true for the FJ62's(it has been a long time owning one of these). these tranny's were mechanical no electronics to speak of.
These is a company in OZ that sells a kit, but wants it to be install on a beefed up tranny. Wholesale transmission, Rodney is the owner. Slee used to sell some of the stuff. late robbie
Robbie,
You have PM
Mine does the same, and according to my 1992 FSM, it IS normal and IS working as it should...remember, this is the non-electronic A440 which doesn't need a switch, the lever does all the work.
Learned something new, normal for 91-92, but not for the 93 of the OP, correct? I don't remember my 93 working that way...
Well my 93 had a ECT button, which changed shift points. I believe it was electronically controlled.
I'll double check when I go out for lunch- but I believe that in my '93 when you start out with the shifter in 2nd it will start in 1st gear but will not go into 3rd or OD.
In my FJ60 I usually start in 3rd gear low range when I'm driving in sand to keep from having to shift/ lose momentum. I was just wondering if there's a way to trick my 80 into doing this same sort of thing as well.
Mine does. :confused:
Clarification: Mine does act like Swowie's.
but I now see that I ought to have read every post in here first, before posting. ;)
I can say "yes" for the '92.
You could swap in a A343 to get the 2nd gear start... but that might be more trouble than it's worth.
That would definitely be too much work.
I was just thinking it would be great if there was a switch that could be installed, like the CDL switch, to add 2nd gear start. I guess I'm just dreaming.
