Adding 2nd Gear Start Switch to a '93???
I live in an area with lots of ice, so you'd think I'd be one to use 2nd gear start. However, I've never felt the need to use it. Not once. Lots of icy hills, etc. I can only see it useful on surfaces so slippery you cannot keep from spinning your wheels in 1st. I have never encountered such a condition, and have even played with it to see if it's useful. It's not. Low range may be a different story, but I can't see needing that for starting up on an obstacle as its purpose is slippery stuff, not wheeling. Seems to me it may even be disabled in low range. I'll check.
DougM
FWIW I use the 2nd start button almost all the time on trail when I am not on an obstacle. If I am travelling moderate trails where I can go "faster" I use 2nd start so I don't get the harsh 1st to 2nd transition.
Comfort more than anything...
I was not aware there was a difference in the transmissions in the '91-2 and '93-4. My '94 will run through both first and second gears if the lever is in '2'. I assumed the lockout worked on pressure regulation (mechanical) rather than an electronic control.
I had never thought of a good use for the 2nd gear start option in my wife's '95, but I guess it could be useful in low range. I'll find out when I appropriate hers- which hopefully won't be for a while as hers is meant to replace mine when I destroy it. When, not if. :D
-Spike
I'm bringing this thread back to life because the original question is not answered, and I want the answer.:hhmm:
In my '92, It was eisier to climb cinder hills or sand dunes in L4 while the tranny was limited to 2nd gear only. When it kicks down to 1st on those climbs it just spins the tires & sinks.
On my '93, Is there any way to accomplish this same 2nd gear isolation? Using the ECT button in econ mode helps keep it from downshifting as early, but I would like it if I could make sure that it does not downshift to 1st at all.
I have searched many threads, but could not find this answer. Any help would be appreciated. Thanks
