Accelerator linkage to SBC
I reccomend stock GM or LC, or Lokar. dont get the spectre one. its a piece of dooo. you can do a search for it on Pirate and find similar opinions.
If you run a cable linkage, I think you'll need a new accelorator pedal. SOR sells them. The stock GM cable will take some modifications to get it to mount through and into the firewall. Atleast the one off the '94 C1500 did. The Lokar one has a nice fitting that will bolt through your firewall.
If you dont need fancy stainless, go with the stock cable. I ran that for years on my other motor. Then decided to get fancy, so I bought that cheap piece of crap Spectre one for $20.00 and it sucked sooooo bad. It drags and the throttle would actually stick in the off position, so that I had to, very controllingly, apply pressure to get it off idle, without bumping the throttle to 1k RPMs.. It was frustrating. Then I bought the $50.00 Lokar cable and have been super happy with it.
good luck-
Dustin
Stock pedal, modified with a GM cable. If one can put a V8 in, the accelerator mods are no more difficult than the other 500 exercises in creativity.
used the 3/4" wide metal straps used to hang garage doors (the ones with the holes every inch or so) to make the adaptor, along with two nuts and bolts. has worked for years. Put the lc cable end between two 2" pieces in the holes, bolt together and bolt through the chevy linkage on the other end.
