Accelerating and Decelerating Steering Pull
North Front Range, CO
When I accelerate or going a steady speed on flat ground I get a pull to the left. When I let off the gas it straightens out right away. It is a strong pull to the left like if I need an alignment real bad. When coasting it follows the ruts in road or pulls to right if road leans to the right.
I haven't had an alignment in a very long time but my mud tires have about 63,000 miles on them and they show no signs of needing alignment.
With 429,000 mi on it, I am sure something is worn or rotted away but not sure where to look? Tie rod ends only have 200,000 mi on them. Many of the bushing are showing there age and are dry and cracked.
I have had a problem years back with the right front wheel bearings coming lose over and over again. I had no pulling but the tire did wear more very unevenly. I will check bearing again. They were good as of last winter/spring but been on the road all summer and have not lifted the 80 off the ground sense then.
Will check them next day off. I will use my ir temp gauge to see how hot brakes are tomorrow.
LOOSE WHEEL BEARING it is, AGAIN!
Don't understand why its always the right side that gets loose, left side stays tight and it has more miles on it as I never adjust the left side when the right side gets loose.
Nuts stay tight but the bearing looses preload? Might just be a little tighter tolerances on that spindle. Are you doing the fish scale method or the torque method? If you run larger tires you can up the specs a little.
I have used both. Torque method has lasted longer.
I bet the big washer is going to be worn more. I guess the loose wheel bearing could be from the wear spot on the big washer???
Maybe I have one washer that is softer metal than the other?
The PO must of had a mechanic that didn't have the big socket as the nuts have marks from a chisel or screwdriver. I need to replace both the nuts and washer.
Mine is the left/driver side that gets loose over time. Just completed the second front axel service in 3 years. Going to be a little more deliberate about checking preload and bearings this time around.
Rear wheel bearings were loose. Repacked and it still happens.
Inspected all the suspension bushing and all were dry cracked and some had large cracks in them. Guess that's when the problem is.
Stupid question, but have you checked your tire pressure? Swapped wheels side to side?
Landtoy, I started a thread not long ago with what seems to be the exact same problem . Pulls to the right only when accelerating. Straightens up when letting off accelerator.
I feel sure it is the birfield. It didn't happen at all until I put in another birfield. Actually it was a worn one with 400+k miles. It began pulling to right immediately. I have a newer birfield to put in but haven't yet.
I am very confident that will fix the prolem. We'll see.
Had tires rotated and it still happens.
Mine pulls to the left on accelerating and right when decelerating.
My left birfield is a Chinese replacement from when the Newfield failed. The right is the a real Newfield that has over 220,000 mi and clicking.
The left has a lot less miles and being that its from China its a probably a normal birfield and will wear less. But I am just guessing.
I have a spare China birfield but waiting to see if the Newfield breaks as its still under warranty.
I had similar symptoms. As noted, could be many causes, but for me it was worn bushings in rear control arms.
Lots of these 20 year old rigs are still floating along on the original radius, panard, and upper/lower control arm bushings. The harder you wheel, the more you need to replace them.
