- Joined
- Jan 6, 2012
- Threads
- 342
- Messages
- 10,976
How would static pressure be the same regardless of the amount of refrigerant? The more refrigerant I put into a ac system the more static pressure their is. As far as I know, when r134 is static in a automotive ac system it is always a gas, not a liquid. If it was partially a liquid, you would risk hydro locking the compressor. The state of r134 according to a chemical calculator at 90 or 100psi at 88 degrees is its a gas. A properly charged r134 automotive system static pressure will not be 95psi. According to her static pressures, the system is overcharged quite a bit. But I agree with you that right now the concern should be to figure out why the compressor isn't activating. It certainly isn't due to too little refrigerant.Jen, with the engine off (compressor not turning) you are looking at the 'static' pressure on your gauges. The system will equalize and the readings on both gauges will be roughly the same. The static pressure for 134a at the ambient you cited (88° F.) would be about what your gauges are showing (96 psi). Don't worry yourself with that.
The static pressure is a mostly useless figure EXCEPT to show you have some amount of liquid refrigerant in the system. It does NOT indicate how much is in the system. Static pressure will be the same if you had one drop of liquid refrigerant in the system or two pounds. So don't be concerned with that.
Let's move on. It will be pointless to continue until you find the reason the compressor clutch is not engaging. You have already introduced one can (some amount of weight? into the system) and you have almost 100 psi static pressure, so we know that is enough to activate the pressure switch (if it is not faulty).
Let's turn our attention to tracing the electrical circuit and see IF you have power (12 volts) getting to the compressor clutch.
You'll want to check the easy stuff first (fuses), then dash switches, wiring. But we have to settle that issue before moving forward. Once we have the electrical system calling for the compressor clutch to engage...we can go back to the charging phase. You have plenty of static pressure...so DON'T add more refrigerant at this juncture.
Let us know what you find.
Flint.
Fluid Property Calculator
. Plugged it in, and boom.....AC clutch engaged and blew ice cold air from the vents!
No more sweating it out in the mid day Hawaiian heat and having to drive in a bikini everywhere just to stay cool! Thanks again
