- Thread starter
- #21
The only one that the hose would fit on. I think that would be the Low pressure port.
STOP already with the "pertinent info" line. Help a fellow member will ya.
I guess anything is possible but the charge kit I used had a gauge on and I stayed within the area (on the gauge) recommended.
what pressure did you stop adding the recharge?
It does seem like it could be an overcharge issue. The kits you get at the auto supply store will only allow you to charge the through the low pressure port. Yest they do have a gauge, but doing it this way does not always solve the problem. It might be worth it to get it checked with some better equipment. Then you can be for sure. You'll also be able to check the high pressure as well.
Assuming I may have a small leak which would be the reason I needed to recharge. Could I have overfilled slightly and with a small leak the pressure is coming down into a safe range and maybe (this is a big maybe) the problem is going away?
Ok, went out and picked up a "EZ Chill Air Conditioning Recharge & Retrofit Kit". I't cam with a instructional CD, 12A conversion fittings, three cans of 134A freon and a conector hose with a guage all for $34.99. Watched the CD in WMP (on a Mac) and recharged my LC and PU in about 20 minutes. Also cleaned all the fins in the rads too.Was never able to find the sight glass window. Must be buried under something or maybe behind the rad overflow container. Now I need to look into the newer blue fan clutch.
Thanx,
Rod
Sounds like this is a single gauge setup. Are you able to monitor the high side and low side pressures with this? From what I've gathered here, sounds like it's important to be able to monitor both.
I think everything has been covered as far as what to do.
