A/C not Kool enough
S. Jersey - New Germany
Before I went ahead and put my LC in the shop to have my A/C checked for leaks and get it re-charged, I though I better check here to see if there was anything I should know before I went any further.
Right now the A/C works. It does blow cool air, but I have to have it on high and it never seems to get that cold. I'm guessing that I just need to get it re-charged. What do you guys think?
How are your engine temps? It is possible the system is both low, and that your cooling system isn't cooling the condenser down much, so the combined effect means mediocre vent temps.
Engine temp always runs right were it should be.
My advice is to check for refrigerant in the bubble view window (it's a little window on your a/c lines, I believe on the driver's side in the engine bay near the headlight). If it looks good, take a hose and some simple green cleaner and (WHEN THE CAR IS COLD AND HAS NOT BEEN WARMED RECENTLY) clean out the radiator fins. This will help cool your car considerably.
What should I look for in the view window?
Have you modded your temp gauge? If not, the AC cuts out before the needle moves. Even if it doesn't get hot enough to cut out the AC, if the engine is running hot due to a bad fan clutch, it is also not pulling as much air through the condenser.
I'm with Curtis. You can recharge your own system with a kit at any auto parts dealer for under $50 and about 15 minutes. Look at a factory manual for any vehicle with a sight glass on the a/c system that lets you look for bubbles. Don't get ripped at a shop for a $200 evacuation and recharge. They'll tell you your system will blow up, your hair will fall out and your children will be porn stars if you don't let them rip you off. You can charge your system at home in the time it takes to drive to their shop. Plus a few years later you can do it again since you have the kit. They hate those kits!
I'd also clean the radiator and a/c fins and look into installing a newer blue clutch instead of the green clutch you'll find on your 94's radiator fan.
DougM
DougM
If you do decide to recharge the AC on your own, do invest in a A/C manifold gauge to monitor the pressure. The sight glass is only useful to show the low refridgerant and not a good indicator of then the system is overfilled.
Overfilled AC system can cause blowouts, typically in the couplings and compressors. I've also seen blowouts of the refridgerant cans from the feedback of the overfilled system.
Very few of the older Toyota's seem to blow at their coldest in the high setting. Unfortunately, it is considered normal. If it is blowing frigid on the other speed settings, you probably don't need to do anything at all......meaning, spending over $150 at the dealership probably isn't going to yield any worthwhile results.
I'd also clean the radiator and a/c fins and look into installing a newer blue clutch instead of the green clutch you'll find on your 94's radiator fan?
DougM
DougM
Ok, went out and picked up a "EZ Chill Air Conditioning Recharge & Retrofit Kit". I't cam with a instructional CD, 12A conversion fittings, three cans of 134A freon and a conector hose with a guage all for $34.99. Watched the CD in WMP (on a Mac) and recharged my LC and PU in about 20 minutes. Also cleaned all the fins in the rads too.:cool: Was never able to find the sight glass window. Must be buried under something or maybe behind the rad overflow container. Now I need to look into the newer blue fan clutch.
Thanx,
Rod
Thanx,
Rod
Open your hood. Look directly "above" the battery on the far driver-side inside of the fender. It should be there.
OK! I found it, didn't realized it would be tucked under the fender with its window on the side. Actually it's right next to the battery on mine. After the A/C is running for a little while the window has like a flow of fog moving through it. Right?
Bubbles means it's low.
You want to fill it just to where it runs clear under the following conditions: Truck running, A/C on high, fresh air vents rather than recirculate, doors or windows open, outside temps 90-95deg farenheit. (Check FSM in case I'm misremembering any of this.)
Curtis
P.S. Why the heck aren't you sharing with us whether what you've done so far has helped??
Curtis
I did - Read post #12 and #15
Thanx,
Rod
Well, did that help? Inquiring minds want to know.
SO? Did refilling help?????
I did. Where in either of those posts do you think you've said anything like, "...and now it cools like new!", or, "that was definitely the problem", or maybe "it seems to have helped a little, but..."
I mean, c'mon; I was the third person to ask you for more details on the results, and you still haven't given us any.
Curtis
Hey Curtis, in the #12 post I thought it was clear but if not I'll spell it out for you.
I BOUGHT A KIT AND RECHARGED THE A/C ALONG WITH CLEANING THE FINS IN THE RAD.
I T __N O W__I S__R U N N I N G__C O O L E R.
