So it started out as an expansion valve replacement. But then it crossed my mind that at some point other failures will happen in the old system so I decided to replace the entire AC system. Replaced the expansion valve, evap, compressor, condenser, and receiver. Hoses were fine.
Everything hooked up and now it won't take a charge. Pulled a vacuum, got some R12 in there, jumped the compressor to get it moving and nothing.
Compressor now will turn on but runs continuously with no cold air and no cycling.
Any thoughts? Did I get a bad expansion valve?
It was a real paint to get the refrigerant in there in the first place. Its R12 but used compatible oil so can switch right over to 134 if need be but obviously that is irrelevant at this stage.
Thanks
Brandon
Thanks
Brandon
