- Thread starter
- #41
Did they give you the high and low side pressures?
They didn't give me any pressures "its a little bit low, but in the range" was the wording.
The problem with AC is there are a lot of misconceptions even among technicians. In range at idle can still be under filled. Mine was in range at idle. 28 psi low side 215 high but as soon as the rpm came up it almost dropped to 0 low side. A small recharge has made a world of difference even at idle. Took less than a pound of coolant to fix.
I find the need for aux fans at idle for both our FZJ80 and LX470 to get freezing cold AC temp when its 115°+
Anyone that tells you an aux fan does help does live where it hot
IN my experience, the recent install of an aux fan (Spal) has significantly help the efficiency of the A/C while at idle and stop-and-go traffic (ambient temps in the mid to high 90's). The difference is noticeable
However, I have been always careful having lip-sealed the gap between the radiator and the body. I don't think some folks realize the impact (loss) to the air flow of such a gap-particularly at idle and/or low speeds.
Cheers
fj80pb
Weather stripping from Lowes / Home Depot works great for radiator saddle gasketI was pretty upset when Big-o not only dented my hood working on my car (which they never did anything about) they also ripped that foam between the rad and the body all to hell. Turns out getting replacement foam isn't easy, so Instead I simply tapped up the gap with high temp gaffers tape (300+ F) which is holding up nicely.
Interesting how my all electric system is waaaay more efficient than the stock units, in particular when going slow or idling.
regards
Dave
The numbers don't lie Tools, witness mechanical systems becoming obsolete even on big heavy 4x4's, why?
regards
Dave
Buddy of mine just bought some big-ass, get-out-of-the-way Chevy 4x4 for hauling his boat around. Didn't come with the tow package, but when he added that on, they switched from an electric fan to a clutch fan. Why?
Who knows? Perhaps there is not enough space to fit a powerful enough electric fan? Or as per Dimples, it was an addition? Or if they needed to fit a bigger electric fan then they would need to alter the wiring, perhaps fit a bigger alternator?
I have said it many times, you CANNOT just bung on the nearest fan from the local junk yard, and expect it to work.
regards
Dave
You can change the fluid in the clutch, and yes this will drive the fan harder at idle, and unless it uncouples completely when at speed , then the engine will continue to drive it even when going along the highway, in effect throwing fuel away. Yes the alternator see's the load and this uses fuel in the same way the VC unit does but, the amps are drawn at the time the fan is on, when it switches off then it is off. There is no parasitic drag whatsoever, the VC system cannot claim that.
