Interesting. I'm definitely experiencing the short run duration after I shut my engine off. I believe my setup is the same minus the manual switch.
What year?
What year?
Another 100+F hot day, but only drove around the block (~5 mins) with the AC on for a couple mins. The medium pressure switch kicks on immediately when you turn the AC on and seems to just stay on for a long time, way longer than the 30 seconds to 5 minutes people are reporting here. Running a 91 that I believe was converted to the newer gas years ago.
Curious to try in colder weather but then also you dont need AC in colder weather.
The mod I did today was to run the pressure switch in series with a cabin switch. The switch illuminates when the pressure switch is active (indicator if the fan will run in on mode or not), and the switch as an on/off override for the fan, since the after run isn't working the way I wish it were.
Worst case scenario, I can just take the pressure switch out and have a cabin controlled fan.
My medium switch comes on immediately with the AC in the morning when the car has cooled off. As I write this, the medium pressure switch is still 'on' (though I switched the fan off). Agreed it sounds like I need to confirm correct system pressure. Thats what I'll plan on doing next.
The 91 is old enough to where it came with the older refrigerant gas type (can't recall the names right now), and the carfax made it look like it was switched over to the new gas by the dealer years ago. Perhaps the switch is tuned for a different gas? Or was not switched over properly? Other questions I'll be lookin into.
FWIW I have a 97 and it turns off in 2-3 minutes after a 45 min drive in 100f ambient heat.
New OEM pressure switch is only $36. Any idea if you need to depressurize the system to change that?
EDIT: yeah looks like you do. I'll inquire about throwing a new one on when the mechanic re-does the refrigerant to the proper amount.
forum.ih8mud.com
Yes you can. Just share the pressure switch trigger wire to the relay.Bump to this fantastic thread! Thanks to Sumotoy (who appears to no longer be on mud) and all the other contributors! I am an electrical n00b. Just wondering if I can wire this as described many times BUT use my SwitchPros if I want to override the fan to turn it on at any given time.
thanks for the info, sounds like you've been down this road beforeYou're confusing the repair wires with the terminals; only the repair wires (as opposed to the terminals, with part numbers) are listed in the repair manual, as this was intended to be a shop resource. The repair wires are a terminal, sealing grommet and (approx) 4" long wire. The intention was the shop mechanics/technicians would cut a bad wire from the harness and, using a butt connector, splice in a replacement wire, to save time. Since your time is free (you don't charge yourself, right?), you should repair/modify the harness the way it was originally built, IMHO.
2.3 and 2.3II terminals are interchangeable in the housings; the 2.3II allow for larger diameter (gauge) wires to be used (the "D" dimension). Check with Ballenger for terminals, seals (grommets) and housings. They also have sets of complete parts that you can use to make up the connection(s) you need. Search for Sumitomo parts for sealed housings; Sumitomo and Yazaki are both used for the non-sealed housings and terminals.
for real. this.Be very careful about wire gauges and outer diameters. The US/JIS automotive standards are not equivalent (and to make matters worse, you have to do math to equate them because we size wire by the die that makes it, they size wire by the cross-sectional area, which is how the EEs calculate the size required), and Toyota specified different insulation thicknesses by specifying different wire types. That's why there are different seal sizes for the same conductor sizes.
You need to measure the wire insulation OD, then pick the seal for that. The terminals are easier; 2.3II will accept a wider range of conductor sizes than the other terminal types, for the same housings.
