- Thread starter
- #1,101
Water proofing. I gallon used engine oil, 4 gallons of diesel. 3 coats. Trick from an old geezer!
I still need to do this !!
shhhhRemember, Michigan is beautiful!![]()
Looks like a one of those fancy iridium or similar plug$ VS regular.
Of course it was number six needing the extraThey were all NGK. Looked like wierd arcing. Went in with Denso OEM. Yazaki #6 plug connector had separated from boot as well. Rotor and cap had some arcing also which are getting tossed and Yazaki OEM going in.
Ya you have to remove throttle body, heater valve, wire harness mount so that you can get to that plug. Had to use a forceps to fish it out of the plug tube because spark plug socket would not latch on.Of course it was number six needing the extra![]()
My buddy just had to deal with the exact same thing a month ago.Ya you have to remove throttle body, heater valve, wire harness mount so that you can get to that plug. Had to use a forceps to fish it out of the plug tube because spark plug socket would not latch on.
