- Thread starter
- #1,081
Snagged this for $50 local. Old iron Dayton. 1750 rpm. Been looking for one.
You lost me at numbered 1 - 11….That was a 12 pack. Correct about not finding what I need.
What I noticed while sorting.
Bolt heads are numbered 1-11. Numbers 1,2,3 are not numerical. Number one has no marks on bolt head. Number 2 has two dash marks on bolt head. Number 3 has three dash marks on bolt head. Numbers 4-11 are numbered numerically on the bolt heads. Each number ID has three diameter shaft sizes. I just organized the bolts by bolt head ID. Within each bolt head ID, I organized by the three shaft diameters. Each shaft diameter has different bolt lengths which I did not separate out more. I would pick length as needed once I match bolt head ID and shaft diameter. Bolts numbered 7 or 11 are most often drive shaft bolts. I will match thread pitch on a as needed basis.
Decked the trailer. Ready for fetching.
I wanted to torch it off but…. You read my mindView attachment 3498469
You should put a ball there so you can pull a second trailer. Why only pick up one new project at a time?
It became critical path. Nothing exciting initially. I have some carcasses in the back that need to crushed. A bent s10 roller chassis, an fzj80 body, a crusty canadian hj60 frame, and possibly an old chevy 3100 roller chassis. Also need it to place chevy 3100 cab and bed on while we build the s10 frame to put under it. Need it to get things to the sand blaster. Bridgeport mills weigh less than 7000lbsExcellent, can't wait to ses what's next on the fetch list!
Bridgeport mills weigh less than 7000lbs.
Need me to swing by Bro?Tiny terminal 60 at the end of the white rectangular connector
