A dumb brake line question........
Wild Idaho
Should you use some sort of thread sealant when installing new brake flex lines? Did the RDB conversion, and can't seem to get rid of a leak at the tee on the rear axle....... Bueller? Anyone?
You should not require any type of thread sealant. Either you are not getting them tight enough or you may have a bad flare hard line flare that will have to be cut off and reflared. If it is a defective brake hose you will have to replace it or find a place to cut off the hose end and crimp a new one one.
the T has flare fitting on the hardline and uses a copper washer on the soft line coming down off frame , which is leaking ?
If the flare on hardline has been done and undone say 4 or more times it prolly needs to be cut and have new flare put on, it is easy as pie.
The flare fitting is leaking....I am using the downey stainless braided brake lines, so they should fit fine. Guess I'll pull it apart this evening and see what is wrong...I've tightened it down pretty hard..much more and I'm afraid I'll strip it out! It must not have seated properly...:(
Well, after tearing it apart, I found that the flare on the downey line was too deep, not allowing the pointed end of the flare in the tee to mate with the concave downey fitting.:( So, I decided to flat file off the end of the downey fitting about .025" and see if that would allow the surfaces in question to mate....It appears to have worked :) Time and pressure will tell.
Cheers!
