Just want to get a feel for what are the hidden costs and headaches of a swap from 94 into 97. harness issues? transmission? etc. Is it plug and play or will I need some sort of adapters?
any Cons?
thanks folks
so that's not good are you positive? FAQ said 1999 and above were obdII, but that could be a typo....
And if I have the chance at engine and tranny any reason to not go that route?
to the best of my knowledge you can put the OBDII engine in the OBDI trucks if you swap the wiring harness and intake from your truck to the newer engine.
Keep it simple and stick with 93-94 stuff. Cruiserparts.com in New Hampshire sells used engines. Some are freshly pulled, some have new HG's and some they sell are rebuilt. It's not a cheap engine though.
Jumper? As in for the egr temp sensor? My 94 has a temp sensor but my 93 does not. I have not torn into the 93 yet but I don't even see a wire connector for a temp sensor. It's my understanding that the 93-94 harnesses are identical.
i currently have a 96 engine bolted to a 93 trans ready to drop into the 93 but then the weather went south and we had a medical emergency in the family so it has been put on hold until spring. i swapped my 93 intake and wiring harness to the newer engine and everything fit just fine. i see no reason it shouldnt work just the CPS isnt connected.
I don't have to smog test in my county and by the time I do it will probably be a classic. Whats CPS? cheap harness source?
Trying to figure costs of several options.
You don't have to swap harnesses you stay obd1 I think it was too extra sensors the 95 and up have extra knock sensor and can't remember the other, plug and play pretty much
I have been shopping radiators because mine is not to be trusted now anyway and I notice that they are inconsistent in model year fit some say 95-97 some say 93-97 some say simply 1997. I will need a 97 radiator if I get the engine right? Are the holes in my 94 cruiser gonna fit a 97 model rad?
Whoever said you don't need to swap harnesses and that it is plug & play is dead wrong.
As someone else correctly said though, you can put your engine harness and intake manifold on an OBDII block and everything will work. You'll just have the crank angle sensor on the oil pan sitting there with nothing plugged into it.
The engine harnesses are very different. To start with, on a 94 the transmission computer (TCU) is in the driver's footwell, and separate from the engine computer (ECU), on 97 they are integrated. This means the 94 engine harness needs an extra connector (IH3) to provide the 16 circuits from the engine harness to the TCU on the dash harness.
I know for a fact that a 94 has two knock sensors.. if they added a third to the OBDII engine I'd be surprised.
After that, LOTS of other wires got moved around on the IH1 and IH2 connectors. On a 94 the tach signal goes from the coil straight to the cluster.. doesn't go through the engine harness. on a 97 the tach signal goes from the ECU straight to the cluster. On a 94 the EFI MAIN power circuit goes through the engine harness, on a 97 it goes through the dash harness.
IIRC the A442F transmission in a 94 has a different number of solenoids than the A343F in a 97.. so AFAIK you can't even trick one TCU to control the other.
All of that said.. use the 97 block, your 94 harness/intake, and your 94 transmission/torque converter. That is as close to a bolt-up option as you have.
Thank you sir, will I have bugs or a tricked computer? I don't believe this is my best case scenario but its affordable and convenient now and I can rebuild my 94 block over time and do a better job sourcing parts patiently.
is the 97 engine coming as just an engine or is it complete with intake and all accessories on the front?
if it is just the bare engine then bolt all of your parts on it.
if it is the complete pull out then take the intake off and the main harness off (it is snaked all into the intake so no big deal) and bolts yours on it.
this isn't rocket surgery. they are the same engine. keep your factory transmission.
