97 engine in 94
is the 97 engine coming as just an engine or is it complete with intake and all accessories on the front?
if it is just the bare engine then bolt all of your parts on it.
if it is the complete pull out then take the intake off and the main harness off (it is snaked all into the intake so no big deal) and bolts yours on it.
this isn't rocket surgery. they are the same engine. keep your factory transmission.
It is complete. Looks like almost everything but the fan.
I know it should be easy I'm just concerned about little gremlins like the one that caused mine to end in disaster.
My sensors weren't working or my guages and that lead to me continuing along down the highway with a hot motor which put me in this predicament.
I jumped on a vehicle because the guy rushed me, looked at the odom and the condition of the body and missed alot of clues in the engine bay and didn't do my due diligance. Don't want to do it again and be further in the hole.
Just want to vet the knowledge on here and it seems split between go with the right year and swap her.
Thank you sir, will I have bugs or a tricked computer? I don't believe this is my best case scenario but its affordable and convenient now and I can rebuild my 94 block over time and do a better job sourcing parts patiently.
If you put the 94 harness/intake onto the 97 engine your computer won't know the difference. The other way around would be a problem, as the 94 engine doesn't have the crank angle sensor that the 97 ECU would be looking for. Keep your 94 transmission, and as long as everything is set up and plugged in correctly it should fire right up and pose no problems.
In that case getting a bunch of sensors to replace the ones that may be bad on your 94 isn't a bad thing at all.. however it is entirely possible the problems exist in your engine harness (EGR area commonly melts wires in the harness) or dash harness causing those gauges to malfunction.. in that case obviously if you move your harness over to the 97 block those problems will still be present.
IMO you need to address any other issues you mention like gauges or problems in the engine bay before you count on this 97 engine working out for you. Tons of help here on the board for that.. but get a 94 wiring diagram (called EWD on here) and learn how to use it.
Just want to get a feel for what are the hidden costs and headaches of a swap from 94 into 97. harness issues? transmission? etc. Is it plug and play or will I need some sort of adapters?
any Cons?
thanks folks
Don't know where you are on this but Mud member noahfecks has what he calls a good 94 engine with 202k miles for sale in western CO. You can find it in the classifieds parting out section.
When I said plug and play, if you use your intakes, air box you ll be fine no need to swap the harness you stay obd1
