92 landcruiser sludge issues
red clay Ga
Today I cranked up my 80 and like usual the lifter ticks like a diesel, so I decide to check the oil filler port . I notice a small amount sludge was inside ,so I check it with my finger after I cut off the engine . I felt more sludge . I took off the valve cover and almost pass out . There was so much sludge in the cover that I couldn't believe it . I clean out the gel and was so dissapointed that my sis in law obviously didn't change the oil at all . Has anyone come across this problem with their 80 . I'm guessing oil pan has to come so I can check the oil pickup . The engine gets good oil pressure and it sounds normal after warm up . What can I spray to clean the rockers and lifter. My sis in law also stated that she drove from MN to Michigan with no problem . I'm still in recovery mode after seeing all that sludge buildup . Is there any kind of engine flush that I can use . It's crazy that a truck with only 10k miles would have that kind of sludge. I didn't believe it was 120k but she said it's original and can prove it . The truck sat most of its life as she stated .
Oil sludge or coolant in oil sludge?
I have read about running ATF in the oil pan for a few minutes to remove sludge, but I am not sure if it's a great idea to cycle all that freed crud through the galleys and filter.
Well its sludge and I was almost certain I seen a little green at the top of the oil filler port . It might been something else . I'm sure I'm having to go in the pan as well to see if any sludge is vacationing down there . I am so stress about this truck , I have to run new brake line from the middle of the truck back to the rear because it's rusted out . I have no brakes at the moment . I need to replace the birfield , I have to fix the Ac because it's not cooling dued to something puncturing the condenser . This truck might be a little too much for me . This was a neglected poor cruiser .
Take a deep breath and work the issues one at a time. If it runs and drives with good oil pressure nothing can be that bad. You are driving a Japanese AK-47, it can take some abuse.
The truck runs good very solid and the only dissapointment was I didn't get the chance of owning one of these great machine when it was newer. I grew up with these trucks in my younger years but never knew I would actually own one . I currently own a 100 series lx470 and two ls a 400 2000 Canadian model and a 04 ls430 for my dd. I will take my time on fixing this truck ,I'm really excited but just dissapointed on the work I have to do to be able to drive it. I'm a diesel mechanic so fixing car is not a hobby but for a living ,so working on car is not unusual . I would think that if the oil pressure is good , the internal parts are still in good shape .
Tearing into it and fixing problems is what lets you learn your machine. I thought mine was in amazing shape but it turns out the coolant was filled with rust, both birfs were shot, and I got a CEL on the drive home from buying it. I fixed all those and now I know they won't be issues again. It's fun, we'll help you!
Is it this bad?
My 88 FJ62 4.0 L 3F-E EFI engine.
Don't try and clean or add cleaners. All it takes if one chunk to get in a passageway and you will damage the motor from oil starvation.
Go to Bobistheoilguy.com Bob Is The Oil Guy | The Internet's Number One Motor Oil Site
Ask them what you should do. Slow and easy is the way to clean up the motor.
With mine, just a couple quick oil changes cleaned things us some.
Don't worry too much, I drove mi 62 all over the West after buying it with no problems.
Traded it for a Camry a few month later.
I don't know if it is that bad , but it's bad to the point where the top of the valve cover in the inside is all cover with sludge. I started to clean it already but I will use a vacuum to suck it clean ....and I will try to suck in the port of the oil to get everything that I can . Did you just clean it and do a oil change and everything turn out ok ?
I believe that those pic's were from after an oil change. I am trying to find the pic from when it was real bad.
I added nothing per Bobistheoilguy. Just bought some low cost oil like Carquest brand and changed the oil several times. Dont remember how may miles I went between changes. Bobistheoilguy again could help you out.
Had I kept the FJ62 I would of tried something like AutoRX just to test the product out.
Start running diesel engine oil. The detergent and dispersant additive package is more potent and should clean the slugs up slowly.
I can't recommend at what interval to change the oil out while in the clean up phase, that's up to you.
I second bobistheoilguy.com..... lots of info on that site.
I use Rotella T6 (full synthetic diesel-spec 5W-40). Mine was gunky when I first got it, but after two oil changes with a quart of Marvel Mystery Oil each, it is clean as a whistle. I don't use the Marvel anymore, just the T6 and a quart of zddp additive.
Here's a thought or two from an ex SAE engineer:
Sludge in an engine oil reservoir is due to contaminants (nothing new there). They come from one of three sources: 1) the oil, 2) the engine components wearing down and contributing suspended particulate, 3) external contaminants.
The last is the worst case. This is why there are engine seals. They keep out the dust, dirt, water, chicken feathers (you get the idea). Most often the sludge in an otherwise well kept engine is a result of a head gasket leak. Coolant and oil don't mix, but just like your favorite vinaigrette, all it takes is an emulsifier and voila, suspension. The oil breaks down and the engine particulate provides the emulsifier. This can only be resolved by replacing the seal. You can only clean the top end when you do this work, so initial frequent oil changes are necessary to clean the engine. Even then it'll still be dirtier than a new or rebuilt one. I always consider a head job incomplete if the oil pan isn't removed and cleaned at the same time.
You can add solvents to the oil reservoir, but as has been mentioned above, you run the risk of dislodging particulate and blocking a galley passage somewhere else.
The good news is it's a landcruiser and they are overdesigned for the use they're put to. You can get away with less than pristine engine internals, just try to be conscientious and you'll be fine.
It'll have to be rebuilt at some point, clean it good then and keep it that way.
The F motors don't circulate much oil to the head and don't have the best breather system, so tend to make sludge. Have seen some that were very bad, like half way up the valve springs. Most often the contaminant is moisture, from too many short trips, not running often/long enough at full operating temp to drive it off.
I'm in the don't do anything drastic camp. As long as it stays where it is, not likely to damage anything, breaking a bunch of it loose at once is asking for trouble. If the driving pattern is changed, some of it will be slowly broken down into the oil, but the F motor doesn't circulate much oil to the head, so it largely is what it is. :meh:
What I would do. I'd take the rocker assembly off and take it to someone who can clean it. Most machine shops can do this pretty cheaply. Also do the valve cover as well. Getting sludge buildup and clogging the oilers to the valve stems causes premature wear and you will eventually wear out the rockers. Usually I see that when someone goes out and starts a truck for a few minutes then cut it off. Condensation builds up in the valve cover causing it to rust and the oil and sludge stick to the rust. Not a huge deal but needs to be addressed. I've seen way worse than that.
It sounds like an Italian tuneup might be a good first step.
I used some flushing concentrate from these guys Cost Effective Maintenance - Home as my brother in law sells it. Dumped it in with some cheapo oil and it stripped all the sludge off everything under the rocker cover on my 1hz. Between doing that and adding a catch can and being turbo now my oil stays nice and clean between changes.
The bad news is here ,after farther examination I found coolant by the 3rd cylinder . I'm confuse the car don't overheat or smoke, it idle perfect . The coolant in the reservoir is clean , oil is clean in the pan . I'm not too happy with this.
