92 landcruiser sludge issues
You can't. Might do a radiator pressure check. You should be able to rent a pressure tester. See if it's coming from the freeze plug or a crack in the head.
You need to pull the head off and have it machined pressure tested and magnafluxed I had the same problem with my 3fe ,i pulled off the head they replace some cracked valve seats pressure tested it and magnafluxed it cost was about 500$t after its back together put in a oil catch can reservoir off the PCV so it doesn't get as much sludge build-up again
Then it's leaking from that plug then ,that's where most of the coolant was at and around . That's the highest area and it had coolant in it ,so there's no way coolant can go in it if it's not leaking. I can be wrong but see if you can see what I meant .
Get a radiator pressure tester. Add pressure to your cooling system and see if that is where it's leaking. If so you can punch that one out and install a new one. Just be advised that when one fails it's usually because the cooling system was not maintained. The coolant or lack there of starts rusting out the plugs. When you pop the old one out assuming it's leaking after the test look at the back and see if it's rusted.
Just take off The Rocker assembly clean it clean up the oil Galley ports and replace the freeze plugs
I think you have two separate issues. The sludge is "normal". Shoot, mine looked WAY worse than that when I changed the valve cover seal. I left the sleeping dog alone!
Listen to what @Trollhole says about pressure testing your coolant system. And be prepared for the radiator to give up the ghost...
If it's coming out one of the ports/freeze plugs replace the plug. Flush the crap out of your coolant system and run it.
These motors are insanely durable.
Thanks for the help I'm very new to the cruiser and I don't know anything about the old school motor but I'm familiar with Toyota v8 . I will take out the rocker and add pressure to the cooling system and watch the plug if it leak . I'm sure this car sat in negative temperature for years . What I don't understand is the coolant looks really new on the freeze plug but I have some milky color oil all the way toward the last cylinder . The truck idles fine with good oil pressure and I can drive 30 miles and nothing happens . The coolant is not mix at the bottom . It's just in that little area . The truck runs great no skipping or overheating ...strange .
I'm sure this was happening low ago , when I took off the valve cover , I almost had a heart attack . There was slime and gel all at the top inside the valve cover . I can tell you the way this engine is design it will sludge very easily . There's only one drain port and the oil path that it drain from isn't all that great . It's too shallow so it'll get to the center very slow .,but this engine design is so simple and may not need a lot of oil lubrication . I deal with diesel engine all day at work . I work for Deutz Corp and all they do is maufacture diesel engine and service them . I'm still studying the way this motor is setup so I can understand more.
If it were me I would just pull the head off that way you can solve both your problems
I run a quart of diesel fuel through my engine for a week right before I change the oil every time
I follow the advice of @jonheld and piss in the crankcase. It doesn't skip a beat!
Seriously, just about any oil is fine in the 3FE. As long as it's oil. She ain't picky.
For real I run Rotella T6. It seems to be less tractory running that. Or maybe my hearing is going... :meh:
