91 land cruiser pulley tensioner
Power steering, 16630-61030 (discontinued)
A/C tensioner, groved, 88440-12160 (discontinued)
A/C idler, flat, 88440-36100
Typically all that goes wrong with the pulleys are the bearings. All three pulleys use the same bearing. Bearings can be located at Napa, OReillys or a bearing wholesaler. Seems like the AC idler takes two and needs a washer tack-welded in 4 spots on one end. All the others can be pressed out with the use of a vice and a couple sockets or if you have a press that works best.
