9/75 master cylinder options
9/1975 Fj40 with 4 wheel drums. I am having a strange issue with my brakes recently where the pedal goes to the floor occasionally if I’m slowly applying pressure, but if I stomp on the pedal quickly it holds pressure fine without sinking. I’m guessing the master cylinder seals are wearing out so I am looking to rebuild my master cylinder. However I have a 9/75 build date which is right at the time there was a change in master cylinders, and I’ve looked at the SOR site and neither the 7/70-9-75, nor the 9/75-7/80 options look like the one I have.
So the two questions I have are
Which MC rebuild kit do I need? The ports are on the side like the earlier version but the location of the reservoir and port is different
And second question
Instead of rebuilding, Are there any better options to upgrade? I’ve read the 60 and 80 series MC is a drop in replacement. Do I need to make any other changes like different residual valves, different push rods or spacers? Not planning on converting to disks brakes anytime soon unless I can find a later model front axle cheap, but if there was a MC that was compatible with disks in the future I would like to have the option. Just did a little searching and sound like people have used this one?
Amazon product ASIN B00829GXH0
I’m also going to be rebuilding all the wheel cylinders if anyone knows a source for the wheel cylinder seals for front and back (don’t need the dust boots)
The iron bores usually rust before the seals go. Check their condition. SOR might have the cylinder kits. Try to stick with the original equipment type master if you are sticking with drums; I just bought one the other day, but I can't remember where.
@cruiseroutfit is really good to deal with. They stock rebuild kits and quality Japanese made masters and wheel cylinders. They ship parts out fast. Links below:steer:
Rebuild kits
New Cylinders
Thanks!
We would love to help. We stock the full range of new cylinders (brake, clutch, slave and wheel) as well as rebuild kits for all of those items too! Give us a shout @ Cruiser Outfitters!
The change in master cylinders occurred with the change from front drum to front disk brakes. Do you have drums or disks?
Either way, Kurt will hook you up with the right MC. Don’t rebuild a master cylinder when you can buy a new one at a reasonable price.
I put a Wildwood MC on my 70 FJ40 drum brakes three or four years ago and so far am happy with it.
I am with Splangy on not rebuilding when you can get a new replacement at an affordable price.
I tried honing the slave on my clutch. It wasn't leaking, but it was rusted. It seems like the OEM parts have something akin to a plating or case hardening? Thus, they would be that much more inferior to a new unit if you hone?
I personally feel that fresh changes of hydraulic fluid is even more important than using rebuilds, or non-OEM.
I've also had good experience with Kurt and Cruiser Outfitters.
Well I finally got around to fixing my brakes. I'm pretty sure the problem wasn't the master cylinder
That stuff you see piled on the bottom is what's left of the brake pad. And the top pad is just sitting on top of the brake shoe, it fell off when I took off the drum. Actually, I'm not even sure if that's the top shoe or bottom shoe that spun around or what. I don't even know how this happened on one wheel only, I'm surprised it actually stopped at all.
Another interesting development that I found while redoing my brakes is that I had 7/8 rear wheel cylinders all around, on the front and back axle. Apparently they have the same dimensions and are physically interchangeable. I have no idea how or why that happened, but I never noticed it in the last 15 years. Luckily I happened to have a complete set of OEM front cylinders from a spare axle laying around, so after spending 14+ hours of rebuilding the entire braking system last night I think I finally have working brakes again. At least I hope so I haven't had a chance to drive it yet.
