83' BJ42 24v Glow Plug Problems
Mont Belvieu, TX
My 83' BJ42 doesn't start well unless its warm weather. I notice that the glow plug light stays on for the about 2-3 seconds if its 30 or 80 degrees. When it does finally start up it blows plenty of white smoke for about 15 seconds. Would this be the glow plug timer causing this problem?
Thanks
Do you still have the factory super glow system or has he been altered to the Wilson switch.
Do you hear the relay click when the plugs cycle from pre to post glow.
Have you put a multi meter on the busbar and plugs to test them.
What's the age of your plugs have your replaced them and are they after market or OEM.
Have you tried double cycling the glow system when its cold outside.
Dieseler,
- It's the factory super glow system.
- I hear a click after about 2-3 seconds.
- I have not put a multi meter on it, what would I check?
- I replaced the plugs a few years ago with after market but It hasn't had more than 2,000 miles since then.
- I have tried double cycling the plugs but it doesn't help.
I have noticed that there is a glow selection if you turn the key backwards but all it does is engage the starter, any ideas?
Thanks,
Chris
Sometime, only one dead glow plug can give you a hard time to start and blows plenty of white smoke !
See FSM page ST-5
Is there power at bus bar when you turn the key on?
If this is an unaltered 42 you should have 2 stages to your glow cycle the first being pre and then post glow its been a few years since I have started my 42 but I recall waiting for the sound of the click from the relay before I would start in cold weather and sometimes I had to cycle it twice without cranking to get heat into the plugs and combustion chambers.
After the second cycle it would start up with very little smoking and stumbling but it is not uncommon to have smoking and stumbling when extremely cold out you just hold the gas pedal at about the 1000 rpm range to get heat buildup for a minute or two.
It also is not uncommon to get a bad plug I have had this happen a couple of times when buying new plugs it is frustrating when this happens or having one burn out after a few months buy quality plugs don't cheap out on glow plugs.
Continuity is good. Could this problem be the timer?
Did you take off the bus bar between the plugs before checking? A plug works if there is continuity. if only one is working, you'll still have continuity with the bus bar connected.
also, when bus bar is off, diconnect the wire going to it. Measure what voltage you get to it. Easy if you have a max/min setting on your multimeter. If not, have a friend look very closely at the voltage while going on and off the key.
When I turn the key the voltage on the bus bar is 22.5 volts for 18 seconds and then it drops to 8 volts so it appears my timer is actually working. Is that correct? But then I checked each plug individually and there was no continuity. I originally said I had continuity but that is what my mechanic had told me. It appears my glow plugs are bad. Any ideas?
Sounds like your controller is good.
You can most likely just swap plugs and be golden!
Check if there is a name or number on your plugs.
hi, ... 18 second with 22,5V maybe too much time IMHO normally the first stage of superglow is 2 - 3 seconds when warm and 5 max 10 during the winter...
Seen this some where can’t rember but thanks to who wrote it.
saved it here.
Some info saved
Glow Plug Numbers
Manual 12V
10.5V for a 12V Cruiser
1980/10 – 1981/10 Cdn Spec BJ60
Toyota=19850-68010 12V-10.5V
Nippon Denso=067100-1330
NGK 7493 (Y-147T old number)
Bosch 0250 202 058
8.5V plugs for a 12V Cruiser
Toyota 19850-68030 12V-8.5V
NGK Y-128T
ND 067100-1350
APS 5013
EIKO GT208
JKT PT104
MAY PT104
Manual 24V
1980/08 – 1981/10 BJ42
1978/03 – 1980/06 BJ40
Toyota=19850-68040 24V-20.3V
Nippon Denso=067100-1161
NGK 3030 (Y-178T old number)
Bosch ???
Superglow 12V
1981/10 – 1985/10 BJ60
1984/11 – 1986/08 BJ70
Toyota=19850-68050 (51) 12V-6V
Nippon Denso=067100-1680
NGK ???
Bosch GPT-214
HKT PT-146 QGS type
Champion CH-125
Superglow 24V
1986/08 --> BJ70
1985/10 --> HJ60
1981/10 – 1984/10 BJ42
Toyota=19850-68060 24V-14V
Nippon Denso=067100-1460
NGK 2188 (Y-197R old number)
Bosch 0250 202 076
