Build '81 Trekker ReDistruction
Member Build Threads
What I’ve done before is replace the pickup tube complete and silver soldered in the flange.
@beno Santa hooked it up with a later pickup pick up.
Today was a big day!
The wiring harness to the tail lights was roached!
It was so bad I just cut it out and tossed it in a bin during teardown to get it out of the way.
I had poked at it here and there during this rebuild, trimmed out the brittle stuff, bought a weather proof connector and preped it for reconstructive surgery.
Today I walked in the shop, soldering iron and flux in hand, fired up the heater and went to it!
Three hours later, had all tail/marker/back up/brake lights working as they should.
This is awesome, excellent work! Brings back some memories, I loved my Trekker, such a unique and fun to drive rig. I’ll be watching this for sure! :popcorn:
Thank you!
I'll take that complement from a prior Trekker steward. :cheers:
I have been putting the interior back together, working with what I had. Put a couple of shifter boots together to make one work for this truck and reinstalled the hacked up dash with a little update.
1913457
1913458
1913459
1913460
1913461
Also just scored a little bit of unobtainium on eBay last week. These are impossible to find not completely hacked up. This one only fits 79 to 81. I'm happy with my tablet solution and it's staying in a box on my shelf for now.
1914336
1914337
1914338
Picked up a super nice set of tube doors from 4xInovations. <-- link
Functional door latches using the stock body hardware.
Should be ready for them by the time I get this turd out of the garage.
1914503
1914505
1914510
Thanks to @wngrog and his Project Patina, I'm gonna get this thing all sealed up.
He used and seems to stand by this 3M strip sealant. It stays pliable, feels like the stuff OEMs use to stick the plastic vapor barrier between the door card and inner door.
1925825
I will use it where the bed joins the cab upon final assembly.
And I have used it to clean up the gaps between the fiberglass bed and the tail lights since no foam or rubber gasket ever exited there.
Little cleanup and they'll look better than it ever did new.
1925826
1925827
1925830
It's crazy to me, all these little details when it's so close.
Got myself a carpet kit for the cab off of eBay. I'll pull the seats, lay down a bit of sound deadener and the carpet the next time I touch it.
I have also recently pulled each wheel to tend to whatever was needed.
Front calipers (exercised) opened all the way and pumped back tight, fronts we're dragging a bit, this helped. Adjusted wheel bearings, found a bit of play in the lower trunnion on each side. I'll leave this for now. Whole front axle needs going through, but I have a plan :grinpimp:
The rear was okay, I pulled the drums and cleaned up back there. Ordered some new e-brake bell crank pivots and hardware from @beno to reserect the ebrake.
I have changed all the oils, it's full of coolant...
Need to dump some ATF in the PS and check for leaks.
I have fianlly stabbed the gas tank, with new rubber lines. I'm gonna fill it and run the engine on an alternate source at first to flush the rest of the old gunk from the fuel system.
I still need to fasten the bed and cap down.
They have been kind'a half installed since it's return from the fab shop. I should pull all of it and do it right, seal it all up.
I think I'll leave the windows and hatch off for now.
I am craving driving this thing the way I used to want to ride a motorcycle come this time of year. :steer:
Oh, and it's registered and insured! :bounce:
