First, I want to thank @gnarlynick2072,
@Rock40, and others that created this thread as it was of great help while sourcing all the parts and working on the conversion on my 80.
To contribute to this thread, I will add some ideas how we did it on mine. We (
@FJ40Jim and I) went a slightly different route when planning and mounting the transmission crossmember to accommodate for the shorter and more fun H15x type manual transmissions.
We decided to use a Slee Off Road (
@sleeoffroad) Belly Skid Plate and modify it slightly to make it work. I have always loved the Slee Belly Plate as I think it is VERY beefy and very clean:
Features Low profile design Direct bolt on Replaces factory cross member No need to remove for fluid changes Durable powder coat finish Recessed hardware High Strength Low Alloy (HSLA) has nearly twice the strength and impact resistance of general purpose mild steel (A1011 and A36). 30-36ksi...
sleeoffroad.com
(Slee belly plate link functional as of the date of this post)
There are 3 small modifications needed to make all this work and several advantages to doing it this way. Let's tackle what is needed first and then I will address the advantages.
Modifications:
1. The Slee Belly Plate has enough material on the leading edge of the cross member allowing you to just drill the holes forward to accommodate for the H15x type transmissions (see marking 1 in red below). You will also need to drill holes in the bottom of the plate to allow you to put the fasteners in. This will become evident once you start working on this.
2. When you drill the new holes (I can't remember the exact number, but around 2.5" forward), about 1/4 off the transmission mount ends up unsupported. To solve this, JimC welded a 1" angle iron and rounded the edges of the angle iron so it wouldn't be sharp or get caught anywhere (see marking 2 in red below).
3. Since the H15x type transmissions are shorter than the A442 and A343 automatic counterparts, as you might expect, the Transfer case also moves forward. The Transfer case has ribs on the bottom tail shaft housing that will interfere with the Slee crossmember once it moves forward. To solve this, we made a cut on the cross member as shown in marking 3 in red. The portion that was cut, was then flipped and welded to keep/maintain the structural integrity of the crossmember (see marking 3 in red below).
Advantages:
In my mind, there are several advantages of doing it this way. I will list a few, but I am sure there are others I am not thinking about:
1. This approach requires zero modification to the frame, making it transferrable to any other US-based 80-series platform or any automatic 80-series without any additional work required. You can move your complete drivetrain to any other truck virtually in the blink of an eye.
2. The Slee cross member is beefier and stronger than the factory Toyota crossmember. Your transfer case ends up being fully protected by the Slee belly plate and you end up with a stronger mounting solution.
3. Transmission and Transfer Case are now mounted and supported by the regular 8 big bolts that hold the plate to the frame mounted transmission crossmember, but also an additional 4 smaller bolts behind the cross-member portion of the belly plate.
4. Since the location of the mounting structures remains the same as for the automatic transmissions, all the additional aftermarket items that are designed here in the U.S. for the automatic trucks will still work without any additional modifications (specially referring to rock sliders with this comment here. On the first photo of this post, you can see that if you move the mounting position forward, the U-bolt holding the rock slider on the driver side (LHD) will need to be modified as it will then interfere with the new mounting location).
Hope this helps,
-Alberto
