- Thread starter
- #3,281
Mark Farage has laid on the ground and had people drive over him to try and figure out which u-joint was bad.
I don't think I trust anyone enough for that. I'll just remove the d-shafts.......![]()
That will tell which driveshaft needs new ujoints if you have a bad one. The vibes should go away when you pull the offending d-shaft. There's a diff-lock work-around if you don't have the switch.
I was thinking you could put it in Lo (which locks the CD), unplug a connector somewhere, then shift back to high range, keeping it locked.
I'm not finding any info on it though.
The trick is to put the truck in low and wait for the diff lock to engage. May have to drive it a short distance till it locks. Then pull the CDL fuse and then shift back into high range. It should stay locked until you replace the fuse and reverse the process.
Wahoo I learned something all these years.
Let Rob rebuild both at same time.
