- Thread starter
- #3,261
Better call Rob!
You could have a frozen ujoint.
Is the vibration in the steering wheel or do you feel it more in the seat? Are you running a lift if so how high? Any slack in the wheel bearings? Check the u joints. Like Chris said one can be frozen. If you need u joints go OEM. I have yet found an aftermarket joint that fits right. If you still can't find the source give me a call 601-665-8588
Rob
i say it's your tires being out of balance Bang bang. may also need to re tighten wheel bearing nut. mine came loose before after i changed the bearings.. did the whole spin the wheel this way tighten re tighten before hand dance and it still came loose.
well kids I learned something today.. one of my hard brake lines on the driver side was rubbing on the gas tank mount wore a hole in it over time. after I installed my self made sliders one of the mounts ( i made mine to be bolt on) pushed the brake line right on the gas tank mount. I guess it took around 5 years or so to wear a hole..
I noticed my brake pedal pressure would vary from time to time. I figured i had air in the line. so I thought after i replaced the front brake lines i would just bleed the whole system. this was a few weeks ago at Rob's shop. brakes felt like they always did after.
Here is the interesting part…
So yesterday I am studdin' around town and the brake pedal sinks to the floor decreasing my stopping power and pulling my gaze from the hottie on the right to go full WTF, eye bulging, butt clinching , I may have to run over the hottie holy s*** mode. It's an option on the 97 LXs. Here is the kicker.. i could still stop but not until i pumped the brakes.. so i made it home and crawled under the truck to see if there was a leak somewhere. I saw some type of fluid by the gas tank.. not dripping just on the gas tank and the frame .so i found that where the brake line was being cut by the gas tank mount.. turns out the mount was sort of keep ing the pressure in the system… it wasn't till i moved the brake line that it leaked on my face.. a lot.
So glad i found this before i lost brakes completely. Thanks Jrob for the parts. got it up and running and had a nice brake fluid shower to go along with it..
The old frozen ujoint line. Good one.
Somebody probably used conventional lube in the chassis bearings instead of synthetic. Or it could be a blown three-way valve in the upper relay assembly.
#blackhandsmatterMy hands got so black while Changing the brake lines...they almost mattered.
