80 Series General Tech and Classifieds
I'd rather have an ARB, but you have any photos you can post? Also, specifics about how the winch mounts? Thanks.
attachment.php
attachment.php
winch was mounted on a Harbor Freight winch mount plate that was cut/drilled to fit - the handle for the winch was clocked so one can operate it through the bumper vent
thanks - if interested, please send a PM
200??
SWEEET!!!!
Time for some work on Michaela's stock 97 CE. Suspension has 214k on it. Shot. Replacing w stock height OME lift (purchased thru me saved $125) Replacing tires w 2857516 Dueler Revo AT off Excursion. They have 30k on them not even half worn. Going to perform a frt knuckle rebuild with Marlin seals. (Kit from Georg) Replacing front brake pads and rotors
don't let those old rear coils get away. They should work great on debs mythical buggy...
it ain't a myth, i seen it!!!
Time for some work on Michaela's stock 97 CE. Suspension has 214k on it. Shot. Replacing w stick height OME lift (purchased thru me saved $125) Replacing tires w 2857516 Dueler Revo AT off Excursion. They have 30k on them not even half worn. Going to perform a frt knuckle rebuild with Marlin seals. (Kit from Georg) Replacing front brake pads and rotors
Get it WCT! Being in the rubber business has its perks:)
30mm Front Coil Spring Spacers Needed...
I need a set of 30mm front coil spring spacers for my 1993 Cruiser. Seem to be on backorder across the country. Anyone have any laying around?????
Try Man a Fre
Also, MT makes s nice 2" spacer.
