80 Series at my local pick and pull, parts help
I'm planning on going back out, and will let you know
From the CarFax in June 2023:
  • Accident reported
    • Vehicle involved in a rear-end collision
    • Damage to front
    • Front airbag deployed
  • Accident reported
    • Damage to front
Yup, I saw that. Front structure looked good like I said, grill was mangled a little and rigged up to keep working. One of the sides the headlight had been replaced. Core support and everything is perfect on the front end. Was put back into service after the accident. I did look at it the next day to see and the airbags were popped, the steering wheel one was covered with some tape in that area.
@Txagg007 any chance you would list the pick and pull? Need to pull a couple of parts off of it. Thanks
Hey if you’re going there I need the passenger front fender. I will be glad to come to CS and pick up if you can get it
The passenger front fender was not good, in my opinion. The front of it close to the headlight/turn signal was bent up.
I would be interested in the rear bumper. Both sides and the centerpiece. What a waste of a 80 series.
I got the rear bumper off it. One of the sides is torn a little in the corner, but still good in my opinion. It's only torn/cracked on the underside
Happy to let everybody know. Should only need another day to finish pulling the axles, transmission, transfer case, and engine. There is not much left on it though, to be honest
I'm curious how this worked out for you. Was the salvage yard charging you for each item you pulled? Anyway, it sounds like fun!
