80 and overdrive
Philipsburg PA
Somebody brought up the common studder at idle and that made me think about a burning question.
My 96 FZJ-80 won't go into overdrive for the first mile. Is that annoying for everybody or just me? If it's warm it won't do it, just when it's cold. I let it idle for about 5 minutes after work and it still won't go into overdrive for a complete mile. Hmmm
It's just you.
Mine does the exact same. Most likely some strategy to help the transmission warm up to operating temp more quickly.
My Sienna, Camry, 4Runner, and Landcruiser all do this when they are cold.
I think MR T decided it was a good way to warm up the engine/transmission.
The FSM should be required reading. The answer to most Landcruiser mysteries can be found on the pages inbetween those two covers.
But look at the relationship building you get to experience!
This was an emissions design programmed into the Ecu. O2 sensors and catalytic converters must be warmed up to operating temperature in order to work and put the system into "closed loop". Not allowing the vehicle to go into overdrive while cold it allows for higher engine rpms and higher exhaust temps bringing the 02 sensors and cats up to temp faster.
